Hi
I was going though some tabs and my outstanding tab has a 500 page error ( Never really used it to be honest)
Anyway turned on debug mode and got this error message with line 175 in red
Is this a easy fix
Source file: controllers/admin/AdminOutstandingController.php
156:    /**
157:     * Print outstanding calculation
158:     *
159:     * @param int   $idInvoice
160:     * @param array $tr
161:     *
162:     * @return string
163:     * @throws PrestaShopException
164:     *
165:     * @since 1.0.0
166:     */
167:    public function printOutstandingCalculation($idInvoice, $tr)
168:    {
169:        $orderInvoice = new OrderInvoice($idInvoice);
170:        if (!Validate::isLoadedObject($orderInvoice)) {
171:            throw new PrestaShopException('object OrderInvoice cannot be loaded');
172:        }
173:        $order = new Order($orderInvoice->id_order);
174:        if (!Validate::isLoadedObject($order)) {
175:            throw new PrestaShopException('object Order cannot be loaded');
176:        }
177:        $customer = new Customer((int) $order->id_customer);
178:        if (!Validate::isLoadedObject($orderInvoice)) {
179:            throw new PrestaShopException('object Customer cannot be loaded');
180:        }
181:
182:        return '<b>'.Tools::displayPrice($customer->getOutstanding(), $this->context->currency).'</b>';
183:    }
184:
185:    /**
Looking at code, it may happen in few cases:
  • OrderInvoice is not assigned properly to ID order (or rather order is not properly assigned to orderInvocie in database). Can be caused by a module or core itself
  • Order does not exist anymore - quite common if you use any kind of removeOrder module
In both cases, this OrderInvoice does not have properly assigned Order ID (Missing or wrong) which should not happen.
I did wonder.. As I tried delete orders module from my presta ... Have had a 20 to remove. I only saw after that it doesn't remove everything. But was just a coincidence that I pressed Out standing module
