We are trying to import 25,000 products of which 100000 have already been imported using the same csv template.  With this batch we keep getting the error "Property Product->available_now is not valid" however when you look at the IDs with the error there is no property available_now?
Errors occurred:
  • T0K74AT (ID: 12157389) cannot be saved
  • Property Product->available_now is not valid
  • V7W66UT#ABA (ID: 12088294) cannot be saved
  • T6F94AT (ID: 12031597) cannot be saved
  • N3R86AT#ABA (ID: 11965181) cannot be saved
  • T4E61AT (ID: 12028690) cannot be saved
Turned out the error text was in the label.
Edited by Joint Systems
Update
Just to inform. If You have category with slash (/) in name and You try to import products with the slash(/) in category name (the same name that already exist, then result is category with name before slash and subcategory with name after slash. Really annoying.
