We ran the TB cleaner to clean-up all the test data and start fresh.
When we add the new product and try to add the combinations for any products it gives " duplicate entry for key 'primary' " and it does not update the combinations on the product page. If we go back and edit the same Combination, remove Null value and re-add the value it save and update successfully.
Has anyone experience the above issue and if there is any solution to fix the issue?
KD
Hi,
Thanks
KD
3 answers to this question
