MattR Posted August 27, 2020 Posted August 27, 2020 I've seen it's possible to make modifications to sort by top selling... but has anyone managed to sort products by Revws rating? It's something I think would be a great feature.
colorful-ant Posted August 29, 2020 Posted August 29, 2020 Your idea is a very good thought. I would like it very much too. Unfortunately, from my point of view it won't be very easy. - Module product reviews of Thirty Bees, Datakick, and other compatible modules? - What kind of product reviews is useful? What should customers be able to sort by? - The number of reviews? - Top rated products first? - etc. If you use the Datakick module, you have the option of using shortcodes. It's a helpful variant, after all.
datakick Posted August 29, 2020 Posted August 29, 2020 Yes, this feature is on my todo list. However, for this to work without the need for overrides, the thirtybees core should first be modified. The 'sort by' is one of the oldest functionality, and in dire need for redesign / overhaul. Part of this overhaul should be option to extend sorting option via hooks. Once this is implemented, individual review modules can implement this hook, and provide custom sort by functionality 1
MattR Posted August 29, 2020 Author Posted August 29, 2020 Thanks for the info. That dreaded todo list. It never seems to get shorter... It is a feature i'd certainly pay for (when my products have enough reviews 😅)
