datakick Posted April 26, 2022 Posted April 26, 2022 51 minutes ago, RabbitZzZ said: Would you know a workaround to keep it from creating the duplicate entries? Looks like the problem is in the method ajaxCart.hideOldProducts (file ajax-cart.js, can be located in your theme -- themes/niara/js/modules/blockcart/ajax-cart.js, or directly in blockcart module directory) . This method is responsible for removing products that are no longer in cart. But it does not work properly. You can try to modify this method and change it to this one (always delete all products). This is not a proper fix, as it can result in some weird reordering and/or blinking of products in cart, but it should help a little: hideOldProducts: function(jsonData) { $('.cart_block_list:first dl.products dt').remove(); }, I've created issue to track this problem, hopefully it will be fixed properly sometimes in the future https://github.com/thirtybees/blockcart/issues/1
