Datakick - Data manager module problem
Hi,
I am using the Datakick - Data manager module, after writing mails and posting on the developers help forum, and not receiving any reply for over a month, i have decided to ask here hoping that someone else might be using this module.
When ever i use it to import XML data and set the module to use reference no of a product as an ID for the products, only the quantity of those products is updated that don't have any product variants, for the products that has variants the quantity doesn't change.
Does anybody know a solution for it? Thank you.
3 answers to this question
Available quantity for product with combinations is determined as a sum of quantities of all combinations.
You need to import combinations, and update individual quantities
@datakick So what your saying is that if i have a products that has different colours, and every colour has it own unique ID/reference no. then i can not use the module to update the quantity of those product, even though all those colour with their reference and quantity are in the xml file?
You need to update quantity of individual combinations. In import wizard, select Combination as a record type to import. Then match your combinations by some unique id, ie. combination reference. Use update mode, and import quantities. That should do it
