In the admin screen, while I was adding an item, I got a 500 Error.
Now I can't even access the Products section in the backend. Scratch that, I can't even click on Catalog, yet, everything else within that menu I can - except Products.
I already did the Core updater.
Under Configuration Information it says this at the bottom:
Required parameters: Please fix the following error(s)
  • Allow PHP fopen() on your server to open remote files/URLs.
    Test result: fail
Optional parameters: Please fix the following error(s)
  • Install TLS v1.2 support on your server.
    Test result: fail
Tried to add a new item to the site via the Quick Access Tab.
Made it all the way through, then got this page of errors:
The item did add successfully however.
ThirtyBeesException
Allowed memory size of 33554432 bytes exhausted (tried to allocate 5309016 bytes)
in file vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php at line 108
Source file: vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php
89:     * @var array()
90:     */
91:    public $_cache = array();
92:
93:    /**
94:     * fetches a rendered Smarty template
95:     *
96:     * @param  string $template   the resource handle of the template file or template object
97:     * @param  mixed  $cache_id   cache id to be used with this template
98:     * @param  mixed  $compile_id compile id to be used with this template
99:     * @param  object $parent     next higher level of Smarty variables
100:     *
101:     * @throws Exception
102:     * @throws SmartyException
103:     * @return string rendered template output
104:     */
105:    public function fetch($template = null, $cache_id = null, $compile_id = null, $parent = null)
106:    {
107:        $result = $this->_execute($template, $cache_id, $compile_id, $parent, 0);
108:        return $result === null ? ob_get_clean() : $result;
109:    }
110:
111:    /**
112:     * displays a Smarty template
113:     *
114:     * @param string $template   the resource handle of the template file or template object
115:     * @param mixed  $cache_id   cache id to be used with this template
116:     * @param mixed  $compile_id compile id to be used with this template
117:     * @param object $parent     next higher level of Smarty variables
118:     */
Stack trace
1. vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php:108 source Fatal error()
89:     * @var array()
90:     */
92:
93:    /**
95:     *
100:     *
104:     */
106:    {
109:    }
110:
111:    /**
113:     *
118:     */
Edited by bhtoys
1 answer to this question
