Product Comments v4.0.4 - by thirty bees - ISSUES
So I have basically two issues with the module stated above.
The first issue is that the review popup is missing the id_product value in the url for the product image:
https://mydevelopmentsite/-medium_default/warlord-necropolis-skeletal-warrior-grunt.jpg
I really haven't started to debug this yet because depending on the cause it should be fairly easy - just annoying that something this egregiously defective has made it into a released copy of code from the TB Team.
The second issue is that the "Reported" reviews list is essentially an exact duplicate of all of the reviews in the tables while the tb_product_comment_report table is actually empty. [Screenshots attached]
I have other more pressing issues to fix for my migration first, but thought I would post this here now and see if anyone has found solutions to these issues already.
Thanks!
Edited by DarkHorse
clarifying error conditions/circumstances
7 hours ago, datakick said:
File github issue so it will not be forgotten
Since I don't use github unless forced to, for future reference - a link would be helpful... but I will try to find where to post this anyway.
