x97wehner Posted March 9, 2022 Posted March 9, 2022 Hello, Testing out bleeding edge and after updating my dev server instance, whenever I do updates to things like friendly URL, robots.txt, or .htaccess, I'm getting a 404 error. It's this URL /index.php?controller=AdminMeta&token=....... Any idea how to resolve this issue? Thanks.
x97wehner Posted March 9, 2022 Author Posted March 9, 2022 Actually, I went to my old dev server that's on 1.3 stable and I'm getting the same issue.
wakabayashi Posted March 9, 2022 Posted March 9, 2022 Do you have debug mode on? Is there anything in your server log?
x97wehner Posted March 9, 2022 Author Posted March 9, 2022 2 hours ago, wakabayashi said: Do you have debug mode on? Is there anything in your server log? Debug doesn't show any error. Not sure how to check the server log.
x97wehner Posted March 10, 2022 Author Posted March 10, 2022 6 hours ago, x97wehner said: Debug doesn't show any error. Not sure how to check the server log. Actually, I just spun up a fresh tb instance off of softaculous and I get the issue there as well.
wakabayashi Posted March 10, 2022 Posted March 10, 2022 8 hours ago, x97wehner said: Actually, I just spun up a fresh tb instance off of softaculous and I get the issue there as well. Yeah thats why I suspect anything in the server logs. You surely have something like cPanel or Plesk right? There you will find something called "log"/"logs" or so. It often gives important information, when such an error appears. Have you updated your php version or done any change on server side recently?
x97wehner Posted March 10, 2022 Author Posted March 10, 2022 12 hours ago, wakabayashi said: Yeah thats why I suspect anything in the server logs. You surely have something like cPanel or Plesk right? There you will find something called "log"/"logs" or so. It often gives important information, when such an error appears. Have you updated your php version or done any change on server side recently? I haven't updated PHP in quite some time. Been on 7.3 for very long now. I will attempt to find and check the logs in cpanel. 1
x97wehner Posted March 11, 2022 Author Posted March 11, 2022 It ended up being an issue with how TB was rewriting my htaccess via apache. My server company helped with the adjustment so all is good now.
