Hi is the a way of asking peoples age before they enter my website?
I need a Age Verification Module
Darren
Edited by Refillman
correction
  • Refillman changed the title to Age Verification Module
Installing modules direct from github can be tricky because of folder structures. I did it manually. So downloaded the zip file then extracted locally on my computer. Then I went to cpanel (or you could use ftp client) and went to the modules folder. There I created  a folder called only18plus and upload the files from the zip I had downloaded
So that these files are directly inside the modules/only18plus folder
Alternatively once you have downloaded the zip file locally, and extracted , navigate the extracted folder system until you see the files shown above. Move back up one folder and rename it to be only18plus). Then ZIP that folder and you should then be able to install using the new zip
If you still struggle let me know and I will do a few screen shots or a video to show you
