Hi, I successfully upgraded from TB 1.2.0 to TB 1.4.0 but now I encounter this problem: in the backoffice login page if i put my correct credentials and press Enter, the page refreshes to the same login page. If then I just revisit the backoffice page typing it in the browser URL bar, I can access the dashboard without login.
So I think there's a wrong redirect from the login page, or cookies are not seen at first, or the given tokens are wrong.
My server setup
Ubuntu 20.04
php 7.4
MariaDB 10.3
Thirtybees 1.4.0
Nginx configuration (I did it as much simple as possible for the tests):
unbranched
My server setup
Ubuntu 20.04
php 7.4
MariaDB 10.3
Thirtybees 1.4.0
server { listen 443 ssl; index index.php index.html; server_name mywebsite.com www.mywebsite.com; root /var/www/html/mywebsite; ssl_certificate /etc/letsencrypt/live/mywebsite.com/fullchain.pem; ssl_certificate_key /etc/letsencrypt/live/mywebsite.com/privkey.pem; # php rewriting location ~ \.php$ { fastcgi_pass unix:/run/php/php7.4-fpm.sock; fastcgi_param PATH_INFO $fastcgi_path_info; fastcgi_param PATH_TRANSLATED $document_root$fastcgi_path_info; fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; include fastcgi_params; } }
2 answers to this question
