Homslider problem after latest update
I created a new shop and set Homeslider module up yesterday and it worked flawlessly. Last night I got an info about the module update (to v2.1.0), so I let the tb update the module. Today the images are corrupted and the slider does not work properly. I cleared the cache, uninstalled the module, cleared the cache, installed it back and still have the same problem as seen in the attached screenshot.
I tried with different extensions (jpg, png) and it doesn't even work with the original, sample photos. Any ideas what might be the problem?
Thirty Bees 1.4.0, PHP 8.1
Edited by tomek
3 answers to this question
niara theme (and probably others) has its own override for homeslider template that tries to pick images from /modules/homeslider/images/ directory.
You need to update this override template in niara theme:
/themes/niara/modules/homeslider/homeslider.tpl
changes are described here:
https://github.com/thirtybees/niara/commit/15e5338e628fca184a339d6cde66c961bfeb8169
or simply download this version and use it to replace the one in your theme: https://raw.githubusercontent.com/thirtybees/niara/15e5338e628fca184a339d6cde66c961bfeb8169/modules/homeslider/homeslider.tpl
Thank you, datakick!
I've deleted the file from /themes/niara/modules/homeslider and it started to work again. But I downloaded your version of homeslider.tpl and uploaded to the destination - just in case ;)
I upgraded the store to 1.5 (bleeding edge) and despite having the homslider.tpl file replaced the problem appeared again.
Edit: I found that hte images were spoiled - changing the images solved the problem.
Edited by tomek
