officerat Posted July 17, 2023 Posted July 17, 2023 Help, it asks me to create a settings.inc file and I created and made sure permissions were good and still it will not install the shop to my webspace.
officerat Posted July 17, 2023 Author Posted July 17, 2023 1 minute ago, officerat said: Help, it asks me to create a settings.inc file and I created and made sure permissions were good and still it will not install the shop to my webspace. Where exactly am I supposed to create this file and place it?
datakick Posted July 17, 2023 Posted July 17, 2023 1 minute ago, officerat said: Where exactly am I supposed to create this file and place it? You are not supposed to create it, installer will create it itself. The first message means that installer failed to create settings.inc.php file for some reason (probably folder permissions)
officerat Posted July 17, 2023 Author Posted July 17, 2023 I don't know of any other way to set permissions is this not enough to set them in Plesk for the entire folder?
datakick Posted July 17, 2023 Posted July 17, 2023 If you apply it recursively it should be enough (if it's the right folder) There can be other issues other than permissions. For example open_basedir php settings. Or misconfigured apache modsecurity. Or any other. Look into your browser network tab to see what your server response was for the ajax request that failed (the one with generateSettingsFile=true). There might be some clues there. In my case it completed without errors, I guess in your case there will be some error displayed
officerat Posted July 17, 2023 Author Posted July 17, 2023 It was something blocking the install in google chrome, I tried to install from Microsoft Edge and succeeded Your installation is finished!
