bhtoys Posted June 9 Posted June 9 (edited) When I was done adding items to this page : https://bountyhuntertoys.com/store/index.php?id_category=16&controller=category It listed the highest priced condition first for everything. That was about 6 months ago.... Now, it's reversed that, and the lowest priced (incomplete) version is shown first. I'm at a loss, where do I swap that back? I can only assume I did something that forced them all this way. https://bountyhuntertoys.com/store/index.php?id_product=206&controller=product#/38-condition-incomplete_1 Edited June 9 by bhtoys
0 the.rampage.rado Posted June 13 Posted June 13 You purchased Tidy module if I remember correctly? In it there is an option 'Set cheapest combinations as default' If you have used this function you will most probably have to go product by product and change the default combination.
0 bhtoys Posted June 14 Author Posted June 14 On 6/13/2024 at 11:02 AM, the.rampage.rado said: You purchased Tidy module if I remember correctly? In it there is an option 'Set cheapest combinations as default' If you have used this function you will most probably have to go product by product and change the default combination. Well that's a poor feature to not include it the other way as well. It only affects one section, so I guess I'll manually go back and fix them all. Thanks
bhtoys
Edited by bhtoys3 answers to this question
