Recently I started playing with the embedded SQL manager to make queries that are useful in shop maintanance.
I noticed that my products contain information for language ids that are not currently installed (or active). I can't remember if I used to have additional languages in this shop instance before.
Currently I have:
But this query:
SELECT pl.id_product, pl.id_lang, pl.description_short, LENGTH(pl.description_short)as short_description_length
FROM tb_product_lang pl
WHERE LENGTH(pl.description_short)<50;
pulls the following table:
My question is: as I don't have lang ID 3 and 5 could I safely delete all those records (and also every other record, even if larger than 50 characters) for those IDs? Could I use this query for doing so:
DELETE pl
LEFT JOIN tb_lang l ON pl.id_lang = l.id_lang
WHERE l.active =0 OR l.id_lang IS NULL;
If I understand it correctly even if I had let's say Spanish as ID=3 and I remove it and I add it again it will get the next unused langID, not return to 3? In this case why deleting the language is also not deleting all records associated with this ID (products, image descriptions, features, etc.)?
the.rampage.rado
![image.png.b9453be5f3b58d76a18401b36ceea2c9.png](https://forum.thirtybees.com/applications/core/interface/js/spacer.png)
Currently I have:
But this query:
![image.thumb.png.4eb744bb5fe1154c6b706b9a94f52811.png](https://forum.thirtybees.com/applications/core/interface/js/spacer.png)
1 answer to this question
