the.rampage.rado Posted March 29, 2025 Posted March 29, 2025 I recently started advertising at FB (for now with tragic results) and I'm using a module that only connects their pixel. I would like to implement the API as well in order to improve the results. Are there any modules that you use and have this that you can recommend for thirty bees?
x97wehner Posted March 31, 2025 Posted March 31, 2025 (edited) We use Datakick's module to submit data feeds. The ads themselves seem best managed within the meta ad tool. We've never connected the API for tracking yet, as we haven't found a good tool that will connect to TB yet. Edited March 31, 2025 by x97wehner 1
the.rampage.rado Posted March 31, 2025 Author Posted March 31, 2025 Same here for the feed, the module is perfect. But I use this module I found online. It seems to connect the pixel but not the API despite we have field for the token. Probably the module is not completed in this part, I don't know. It comes with the FB SDK but no events are tracked and the integration is stuck at: pspixel.zip
