alwayspaws Posted October 9, 2017 Author Posted October 9, 2017 @lesley Please mark this solved and give the credit to @spidawebs - the answer begins with: "I’ve not had a need to use this feature before, but when you go to import combinations you will see a list of all the available options on the right hand side. Below are all the fields you can import: Product ID Product Reference" Thank you!
Pedalman Posted October 9, 2017 Posted October 9, 2017 I can also recommend StoreCommander. I renewed subscription once in 5 years though it always worked. What I am saying is that you get a great product (time saver) for the money and you do not have to spent this each year again (there is also JTL Wawi with JTL Connect you could try for free but it is not a like a module. I walk with the cheapiest Chromebook through the warehouse and have my StoreCommander WaWi if you want so with me ).
alwayspaws Posted October 10, 2017 Author Posted October 10, 2017 @Pedalman budgetary constraints. :(
