led24ee
Gold member
Everything posted by led24ee
  1. Code works until "else if." if I replace these lines what should be changed then first one works. EDIT : It works so also with google analytics enabled. So for me it looks like there is something wrong with this code. Unfortunately my skills aren't enough to fix it.
  2. I don't see any difference.
  3. Well, this was never translatable (if this is correct word) but I need to show price for one item. And under products section "Price" there is place for this unit (piece, meter, pack, etc) but there isn't possibility to translate this. This is also reason why I asked this many year ago. But at the moment this isn't working anymore.
  4. This translation is not working. Or at least there is no visible change. There is also no error. Is this related to TB version or PHP version ? Earlier was TB 1.1 and PHP 7.3 ow it is TB1.5.1 and PHP 8.3.19
  5. LED24.EE https://www.led24.ee
  6. Still nothing ? Maybe it is faster install once again and this time write somewhere down password and user.
  7. I have no idea what's the point of this, but You can do thing like this with customer group. So they can't see anything. When customer creates account then it's default in group "Customer" and You can set that this group can't see anything. Then You can move this customer to another group which have different access. At least I hope this can work. Of course, first You need to make this another group where You can move customer. This will work with not products, but categories.
  8. I don't understand why is there need to create user via MyAdmin ? This is some kind of joke or what's the point of this ? And maybe I'm wrong but there is no actual password in database, there is checksum which is combined from password. Password is only the name of this cell or row. For me it looks like dentistry through the butthole.
  9. If I look my log files then I see about 1000 request per day where someone is trying to insert something in database. Some day more, some day less. I even banned some IP ranges based on country. There was also pretty quiet time when some years ago OHV server farm burn out. There are groups in FB where constantly can read about "help my shop is hacked" or something similar. If this hasn't happened to You, be happy.
  10. This is weird. Update is done already, but there is still need for update. Even versions are visible.
  11. Then I need some help. I'm unable to work out how to do this.
  12. New installation is working. Previous one still not working as expected. So I'm pretty sure this timeout error is somehow related to database.
  13. Are these modules bounded with one installation ? So You can't use these in another installation ? If yes is there any way to cancel current one and start new one ?
  14. I just talk with them. They have strict rules about patch and upgrade. These are done inside week and never even on Friday. Last patch was done week ago. My problems started on Sunday, so this TB1.5 was working with patches almost week. But error is still present and I can't find anything in log files and this TB 1.5 is test site. I was trying to import CSV files, there are something like 10 000+ products. So I try from zero. If error is gone then it was probably something with databases, they're too big or there is something that is not accepted. I will not destroy current thing, just making new one.
  15. Now my TB1.5 stopped working. When open Products then after some time You get info that not all tabs are loaded and try again or contact Your server admin. I tried "cache cleaning", browser cookie cleaning, log off-log on and different types of cache settings. So far zero results. I haven't changed anything on my host side. Any ideas ?
  16. Check permissions in category page. Scroll down and check Group access permissions.
  17. I can't replicate this error anymore. I truncated tables "feature" and "feature_lang." But I still can't import value "Public name" There is no error but also this value will not present. Second problem for me is that there are some characters that are forbidden. But differently, and depends what You are importing. This character (slash - /) can exist in CSV file when dealing with category. But it is forbidden when dealing with products.
  18. There's field "Property Feature" where You can put different data about product. This is not working. When importing then data validating is done with no errors, but when importing start after validation then I got error "Property Feature->public_name is empty" This exact field was for different data before. Is this error related to checking ? I mean is there possibility that only filed name is changed, but checking method for this field was not touched ?
  19. So this is somehow "bundled" with this file also ? .../modules/purchases/views/templates/hook/product.tpl These values appear in Products (tab - > purchases), but these can't be translate at the moment.
  20. Isn't there is something wrong with PDF translations ? There are many entries with : ' mod='
  21. Thank for explanation about php 7.4. This version was never used on my web host. Also there is Platium member on one logo. Is this typo ?
  22. I don't get it. When downloading TB 1.5 then file name is this : thirtybees-v1.5.0-php7.4.zip What 7.4 ?
  23. Is there any way that new business client registration can be normal process ? At the moment teher is "Clien name" where You can put company data also. And then there is "Client address" where You can put all this again. I have no idea why there was need for this, but can this all be done in one place ?
  24. I tried PS 1.7 And yes this is very good platform ... for these who just want to pay for every "so called" module which in some miracle reason are already present in TB. But this was long long time ago, maybe now there are some changes. The most annoying part was with translation. I couldn't find possibility to export all existing translations and then after some modification import these to a new version. So for me this was extremely useless thing.
