Hi, I have some problems using the full page cache.
Even with all options in red, it caches more than it should so it creates problems. For example:
(Using panda theme)
- in a desktop, It shows mobile version (I suppose the first user on the page was using mobile and it is the version is saved)
- When I edit something using Visual composer and full page is activated, even if I clean caché I can not see the changes. The only solution is to deactivate the full page caché and activate it again to see those changes
All these problems with all the module options in red (So I do not know why it even happens)
rubben1985
Hi, I have some problems using the full page cache. Even with all options in red, it caches more than it should so it creates problems. For example:
(Using panda theme) - in a desktop, It shows mobile version (I suppose the first user on the page was using mobile and it is the version is saved) - When I edit something using Visual composer and full page is activated, even if I clean caché I can not see the changes. The only solution is to deactivate the full page caché and activate it again to see those changes
8 answers to this question
