Smile Posted December 18, 2018 Posted December 18, 2018 I am wondering if there is made any change or progress is thirty bees concerning packs and the use of combinations. This has not been possible in PS. But a pack with clothing (and its sizes) is really something I am looking forward to. Also beside this the option that a pack calculates its own stock depending on the products it consists of.
wakabayashi Posted December 18, 2018 Posted December 18, 2018 I completly agree on your points. But there hasn't been any change in tb compared to ps.
Smile Posted December 18, 2018 Author Posted December 18, 2018 I would love to make a fundraising for it :) But the question is how much work is it and is it possible?
wakabayashi Posted December 18, 2018 Posted December 18, 2018 I can understand! I guess it's only possible once this project is in 1.1 stage. It will be quite a big work... I have coded a similair thing in an internal module. It took me weeks to synchronize all stocks correct. But my module works a bit different, since technically we create normal products for packs.
dosbiner Posted December 18, 2018 Posted December 18, 2018 yeah thats a lot of work. for your solution there are several modules https://addons.prestashop.com/en/search?search_query=bundle
Smile Posted December 18, 2018 Author Posted December 18, 2018 Well the only one which can do stock and combinations is: https://addons.prestashop.com/en/cross-selling-product-bundles/1015-advanced-pack-5-create-bundles-of-products.html If I am correct seems a bit overpriced for what I need..... Any other tip?
