Lots of errors when using/installing panda theme
Hi,
What I use: Thirtybees 1.0.7 Panda theme for TB Theme editor version: v 1.4.4 PHP 7.3 XAMPP
When I’m installing Panda theme I get all these errors:
``` Deprecated: The each() function is deprecated. This message will be suppressed on further calls in C:\xampp\htdocs\webshop\vendor\smarty\smarty\libs\sysplugins\smartyinternalcompilebase.php on line 75
Warning: count(): Parameter must be an array or an object that implements Countable in C:\xampp\htdocs\webshop\modules\blockcartmod\blockcartmod.php on line 264
Warning: count(): Parameter must be an array or an object that implements Countable in C:\xampp\htdocs\webshop\modules\blockcartmod\blockcartmod.php on line 264 [ThirtyBeesException] Syntax error in template "C:\xampp\htdocs\webshop\themes\panda\breadcrumb.tpl" on line 50 "
" unclosed {foreach} tag at line 50 in file vendor/smarty/smarty/libs/sysplugins/smartyinternaltemplatecompilerbase.php 45. */ 46. public static $_tag_objects = array(); 47. 48. /** 49. * tag stack 50. * 51. * @var array 52. */ 53. public $_tag_stack = array(); 54. 55. /** Smarty_Internal_TemplateCompilerBase->trigger_template_error - [line 165 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_compilebase.php] - [1 Arguments] Smarty_Internal_CompileBase->closeTag - [line 202 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_compile_if.php] - [2 Arguments] Smarty_Internal_Compile_Ifclose->compile - [line 570 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatecompilerbase.php] - [5 Arguments] Smarty_Internal_TemplateCompilerBase->callTagCompiler - [line 349 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatecompilerbase.php] - [3 Arguments] Smarty_Internal_TemplateCompilerBase->compileTag - [line 3684 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_templateparser.php] - [2 Arguments] Smarty_Internal_Templateparser->yy_r59 - [line 4392 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_templateparser.php] Smarty_Internal_Templateparser->yy_reduce - [line 4493 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_templateparser.php] - [1 Arguments] Smarty_Internal_Templateparser->doParse - [line 118 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_smartytemplatecompiler.php] - [2 Arguments] Smarty_Internal_SmartyTemplateCompiler->doCompile - [line 283 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatecompilerbase.php] - [1 Arguments] Smarty_Internal_TemplateCompilerBase->compileTemplate - [line 197 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_template.php] - [1 Arguments] Smarty_Internal_Template->compileTemplateSource - [line 155 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php] Smarty_Internal_TemplateBase->fetch - [line 442 - classes/SmartyCustom.php] - [7 Arguments] Smarty_Custom_Template->fetch - [line 303 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_template.php] - [7 Arguments] Smarty_Internal_Template->getSubTemplate - [line 481 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php(157) : eval()'d code] - [7 Arguments] Warning: file(C:\xampp\htdocs\webshop\vendor\smarty\smarty\libs\sysplugins\smarty_internal_templatebase.php(157) : eval()'d code): failed to open stream: No such file or directory in C:\xampp\htdocs\webshop\classes\exception\PrestaShopException.php on line 184 content_5c1b518dd242c4_92877982 - [line 188 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php] - [1 Arguments] Smarty_Internal_TemplateBase->fetch - [line 442 - classes/SmartyCustom.php] - [7 Arguments] Smarty_Custom_Template->fetch - [line 303 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_template.php] - [7 Arguments] Smarty_Internal_Template->getSubTemplate - [line 38 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php(157) : eval()'d code] - [7 Arguments] Warning: file(C:\xampp\htdocs\webshop\vendor\smarty\smarty\libs\sysplugins\smarty_internal_templatebase.php(157) : eval()'d code): failed to open stream: No such file or directory in C:\xampp\htdocs\webshop\classes\exception\PrestaShopException.php on line 184 content_5c1b518dbd1548_03928526 - [line 188 - vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php] - [1 Arguments] Smarty_Internal_TemplateBase->fetch - [line 174 - classes/SmartyCustom.php] - [7 Arguments] SmartyCustomCore->fetch - [line 414 - classes/controller/Controller.php] - [1 Arguments] ControllerCore->smartyOutputContent - [line 823 - classes/controller/FrontController.php] - [1 Arguments] FrontControllerCore->smartyOutputContent - [line 1017 - classes/controller/FrontController.php] - [1 Arguments] FrontControllerCore->display - [line 280 - classes/controller/Controller.php] ControllerCore->run - [line 253 - classes/controller/FrontController.php] FrontControllerCore->run - [line 837 - classes/Dispatcher.php] DispatcherCore->dispatch - [line 33 - index.php] ```
I can only hover around the home page, when I go to any other page I get these errors.
Does anyone know what could be causing this?
Thanks!
(Just reposting from ST-Themes forum just incase anyone already here knows whats up)
Edit: I just tried to reinstall, that did not work.
6 answers to this question
