I want to keep the Prestashop linking system. So I copied the link descriptions from my Prestashop installation (see attached picture). But it doesn't work. Neither the category links (like http://www.bilbil.com/34-chocolade), nor the product links (like http://www.bilbil.com/geslaagd/155-snoepblik-geslaagd.html) work. They result in 404s.
In addition I have a problem that on my home page some pictures show the file-not-found image. But they do have an image and I can't get the image to show. Take for example http://www.bilbil.com/5722-homedefault/chocolade-munten-50-gram.jpg. This should refer to http://www.bilbil.com/img/p/5/7/2/2/5722-homedefault.jpg. But that image is there and the "pretty url" not.
@lesley said in Product links don't work:
Not overrides in your installation allow overrides in apache, https://httpd.apache.org/docs/2.4/mod/core.html#allowoverride
Sorry, this evades me. I thought we talked about TB/PS overrides and suddenly you refer to Apache overrides.
What is your point? Is there something wrong with my Apache configuration?
Nice. As a tip, if you want to actually code your htaccess to your httpdconf, and disable allow overrides it does speed up an apache server.
Thanks for the tip. As a tip from me: your blogpost on installing TB on DO doesn't mention this allowoverride stuff (or that you need to add modrewrite for it). It might be good to add it.
Hmm interesting, I might have to revise it. They must have changed their image for their lamp stack since I wrote the article. I think I wrote it off their 7.0 image when that is what was widely used.
It might be that DO had to redo things for Ubuntu 18.04. I set this droplet up two months ago and probably since then they repaired some bugs (in my install there was no Mysql password).
I used to prefer Virtualmin but the fact that nowadays they don't even activate php reduced my trust.
One curious question: I understand that my pretty url's did not work without overrides enabled. But what puzzles me is that on the homepage most of the images (80% at least) were shown correctly despite being a pretty url. How could that be?
