Product titel can not be changed in multistore
When you want to change the title of a product in multistore you set the top bar on yes. This does not make it possible to edit the product title. But when ticking the checkbox before the title off and on again it becomes possible...
In short: only the tickbox works not the slider....
6 answers to this question
You seem to have a general problem of multistore saving, as you already reported something similair with product description. I can't confirm this issues on my 1.0.7 installation.
2 minutes ago, musicmaster said:
That depends on how you set up multishop. If you defined that every shop can have its own text then you won't be able to change that text when multistore is enabled.
In the past I could change it so seems like a bug. @wakabayashi What would be the way forward?
Where is it possible to define that? :classic_ohmy:
