I've been battling with this one for a bit now. Maybe you guys know the answer?
I'm currently testing Product Update with CSV Import, but I'm stuck trying to update or replace the Product's Feature Values.
Instead of updating the feature values for this specific product, the system keeps on appending / adding the value to the feature.
This is great when you want to have multiple values for a feature (more on this one in another post). However, this is not great when I need to update or replace a product's feature values.
For example, I have a feature called "Rental price" and the initial value is "200". If I try to update this to "300", then the values allocated to this product is "200, 300".
Is there any way that I can reset all feature values for a specific product with a CSV import? Similar perhaps to "deleting existing images" when doing a product image update?
Also, I've tried to do "Custom position", but this does not show up in the filter / layered navigation - which is what I need.
Please let me know if there is a solution or some way to do this with CSV import or if there is a good module that allows you to update / replace a product's feature values?
Acer
Hi
Thanks in advance.
17 answers to this question
