smarterweb Posted March 3, 2019 Posted March 3, 2019 (edited) If you try to reset the official paypal module in a vanilla install of TB (I tried 1.0.8 and bleeding edge), you get: [ThirtyBeesException] [] is not a valid configuration keyat line 1032 in file classes/Configuration.php 1027. * @since 1.0.8 1028. */ 1029. protected static function validateKey($key) 1030. { 1031. if ( ! Validate::isConfigName($key)) { 1032. $e = new PrestaShopException(sprintf( 1033. Tools::displayError('[%s] is not a valid configuration key'), 1034. Tools::htmlentitiesUTF8($key) 1035. )); 1036. die($e->displayMessage()); 1037. } On top of that, the paypal module does not seem to work any longer with knowband's supercheckout module 5.0.5+. Checkout stalls at 80% Edited March 4, 2019 by smarterweb
lesley Posted March 3, 2019 Posted March 3, 2019 Is there anything in your error logs? The only things that really should have been changed in that version is sending over the transaction information to paypal, that was removed.
smarterweb Posted March 3, 2019 Author Posted March 3, 2019 (edited) logs are empty. can you reset the module without issues? I will install an older version (before 5.4) and see if that still works... tried uninstalling, get the same error Edited March 3, 2019 by smarterweb
lesley Posted March 3, 2019 Posted March 3, 2019 You are right, I have logged the error to github, https://github.com/thirtybees/thirtybees/issues/864
haylau Posted March 3, 2019 Posted March 3, 2019 Thanks for the response. Unfortunately that had no effect 😞
lesley Posted March 3, 2019 Posted March 3, 2019 I think you replied to the wrong thread. I cannot see how to move it. I am going to reply to the other thread though.
