I am in the process to move our TB from one VPS to a new one. Both Centos 7. After much troubles I started from scratch and now I think the problem is a wrong php-fpm setting.
I get these two lines in the Apache log. Anyone that can give me a hint what to look for? If necessary I can give ssh access to the server or access to the controlpanel. I would be eternally greatful if someone could help
[Thu Apr 25 18:27:07.640875 2019] [proxy:error] [pid 7890] (111)Connection refused: AH00957: FCGI: attempt to connect to 127.0.0.1:8000 (*) failed
[Thu Apr 25 18:27:07.640927 2019] [proxy_fcgi:error] [pid 7890] [client 63.143.42.253:52290] AH01079: failed to make connection to backend: localhost, referer: https://jv74.se
6 answers to this question
Hello,
Which version of PHP do you have installed on your VPS?
I prefer nginx, after upgrade to php 7.2 I had to change the entry php5.3-fpm.sock to php7.2-fpm.sock in nginx config file (sites-available directory).
I recommend nginx, along with php-7.2 the store works very fast.
location ~ [^/]\.php(/|$) {
        fastcgi_index index.php;
        include /etc/nginx/fastcgi_params;
        # depending on version, could be : include snippets/fastcgi-php.conf;
        fastcgi_pass unix:/var/run/php/php7.2-fpm.sock;
        fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
Edited by Adik
Double check this line in your config /etc/apache2/sites-available/...
 <FilesMatch \.php$>
     SetHandler "proxy:unix:/var/run/php/php7.0-fpm.sock|fcgi://localhost/"
    </FilesMatch>
Edited by Adik
I looked at php.ini and it for sure use php 5.4 which I know will not work. but I have no clue how to force 7.0. I use Centos so I cant disable it via ssh as in Ubuntu
If I had used Plesk on this new one it would be easy. because we only have one shop left we decided to get a smaller VPS and use Virtualmin instead. All about costs. Pleask has got expensive unfortunately
