Bodegadelibros Posted May 4, 2019 Posted May 4, 2019 when i try to update to bleeding edge from 1.0.8 i get this error: ERROR: Failed to download files with error: fatal: path not found: \admin/ajax-tab.php i was looking in my server and i do have ajax-tab *MY ADMIN FOLDER*
0 Traumflug Posted May 5, 2019 Posted May 5, 2019 A backslash? That's Windows, isn't it? The solution is to run thirty bees on a supported operating system, like Linux, *BSD or MacOS. Alternative is to debug and fix this yourself. I'm not aware of a thirty bees developer using Windows, so you're predestined to do this.
0 musicmaster Posted May 5, 2019 Posted May 5, 2019 7 hours ago, Traumflug said: I'm not aware of a thirty bees developer using Windows, so you're predestined to do this. I am running Windows too.
0 musicmaster Posted May 5, 2019 Posted May 5, 2019 I tested it and didn't see any problem... How do you define the path of your shop in the ps_shop_url table? You should use the forward slash - not the backslash. Windows can perfectly handle Linux slashes... 1
Bodegadelibros
i get this error:
*MY ADMIN FOLDER*
3 answers to this question
