Order products in prodcutcategory module by price
2 answers to this question
You will have to modify the module code. Simply change this line to
$category_products = $category->getProducts($this->context->language->id, 1, 100, 'price', 'DESC');
That should do the trick. If you do this modification, you can't update the module to newer version. The easiest way to ensure this is to change module version to some very high number, ie 100.0.0. That's a hack, though. It would be very nice to have an option to *lock modules* in tb core
