SLiCK_303 Posted November 1, 2019 Posted November 1, 2019 When I generate my robot.txt file, it includes the line... Disallow: / Sometime I have the line in there several times. Any clue why 1.1.x BE would do that?
0 Signut Posted November 2, 2019 Posted November 2, 2019 I have just 'regenerated' our robot.txt and found the same result as you. I do not know the cause. We are running latest Bleeding Edge, perhaps it is related to recent changes?
0 datakick Posted November 2, 2019 Posted November 2, 2019 Do you have url-rewrites set up correctly for your languate?
0 SLiCK_303 Posted November 2, 2019 Author Posted November 2, 2019 yes, all have that, except the module-* ones, and Index. Although my list is different than yours, I'm missing several like attachment, favicon, getfile. I'm wondering if there is a way to 'rebuild' this list?
0 datakick Posted November 2, 2019 Posted November 2, 2019 Hmm, weird. Looks like some sort of data corruption. Could you run this sql and paste the results here? SELECT m.page, ml.url_rewrite, l.iso_code FROM tb_meta m INNER JOIN tb_meta_lang ml ON ml.id_meta = m.id_meta INNER JOIN tb_lang l ON l.id_lang = ml.id_lang WHERE l.active = 1 AND m.page IN ('addresses', 'address', 'authentication', 'cart', 'discount', 'footer', 'get-file', 'header', 'history', 'identity', 'images.inc', 'init', 'my-account', 'order', 'order-opc', 'order-slip', 'order-detail', 'order-follow', 'order-return', 'order-confirmation', 'pagination', 'password', 'pdf-invoice', 'pdf-order-return', 'pdf-order-slip', 'product-sort', 'search', 'statistics', 'attachment', 'guest-tracking')
0 SLiCK_303 Posted November 2, 2019 Author Posted November 2, 2019 all of those without url_rewrites...I'm missing
0 datakick Posted November 2, 2019 Posted November 2, 2019 You should run this sql statement to (somewhat) align your database with 1.1.0 version UPDATE tb_meta SET configurable = 1 WHERE page IN ('addresses', 'address', 'authentication', 'cart', 'discount', 'footer', 'get-file', 'header', 'history', 'identity', 'images.inc', 'init', 'my-account', 'order', 'order-opc', 'order-slip', 'order-detail', 'order-follow', 'order-return', 'order-confirmation', 'pagination', 'password', 'pdf-invoice', 'pdf-order-return', 'pdf-order-slip', 'product-sort', 'search', 'statistics', 'attachment', 'guest-tracking'); This will show the missing entries in the list. Then, you can edit them and assign friendly url to all missing entries (except the module-* ones, and index) Then the robot generation will work correctly again.
0 SLiCK_303 Posted November 2, 2019 Author Posted November 2, 2019 For some reason I'm still missing getfile and favicon, should i just add them manually? Any clue what might have caused this problem? And a solution, other than custom one for each person...?
0 SLiCK_303 Posted November 2, 2019 Author Posted November 2, 2019 that fixed most of the Disallow: / entires, but one.... edit: I get this last Disallow: / on a stock 11x be setup
0 datakick Posted November 2, 2019 Posted November 2, 2019 4 hours ago, SLiCK_303 said: Any clue what might have caused this problem? It's hard to explain, because it was a result of few different things. 1) Theme references to page Theme can reference different pages in its config.xml file to set appearance of left/right columns. This display layout settings is saved in tb_theme_meta table. But this table needs existing parent record in table tb_meta. There used to be a bug in 1.0.8 -- if tb_meta record didn't exists, then this layout display settings was not saved during theme installation. What this meant? Let's say that some theme specifies that page 'All reviews' of module 'revws' should be displayed with left column enabled. If you installed this theme before you revws module, then this settings would be lost during theme installation -- that's because this 'All reviews' is not yet known thirtybees at the time of theme installation. If you later install revws module, it's All reviews page will be displayed without left column. If you, however, first install revws module, than the result would be different. During theme installation, this page is already know, so the display preference would be stored. And this page would be displayed with left column. As you can see, we got two different outcomes, depending on order of installation. That's not good. So, in 1.1.x, there's a fix for this issue -- if the page is not known yet, new placeholder entry is created in table tb_meta. And that allows us to register display preference for this page, even before it's known to thirtybees. If you later install revws module, everything will work as expected. If you dont -- well, we only wasted one table row. 2) Missing entries for standard pages in tb_meta There were many missing records in tb_meta table for standard controllers. That meant that you weren't able to specify left/right display column. But also, you weren't able to specify friendly url for these pages. Again, in 1.1.x, these records were added to data pack -- if you install 1.1.x from scratch, all known controllers are represented by their tb_meta records. However, if you upgraded from 1.0.8, these controllers don't have these tb_meta records. But, because of #1, these records will be automatically created. But they are different than those created during installation. Most notable, these automatically generated records don't have friendly url assigned. 3) bug in robots.txt When robots.txt file is generated, system use data from tb_meta table to genrate disallow rules. This mechanism always contained bugs, but they manifested differently in 1.0.8 --> meta table didn't contain all records --> these missing records were NOT represented in robots.txt by respective disallow rules in 1.1.x migrated from 1.0.8 --> because meta table now contains automatically generated placeholder entries for standard pages (with empty friendly url) --> this results in Disallow / rules in 1.1.x installed from scratch --> meta table contains entries for all standard pages --> robots.txt have correct results As you can see, this is a quite a mess. By fixing 2 long-standing bugs, another one is created / discovered. Unfortunatelly, this is the reallity of legacy software. 3
0 SLiCK_303 Posted November 3, 2019 Author Posted November 3, 2019 Thanks for the explanation, and the help fixing it
SLiCK_303
Disallow: /
12 answers to this question
