hey there,
i did a migration from prestashop 1.6.1.23 to thirty bees 1.0.8
After the migration i get every time an error 500 in the backend when clicking on modules and services or when clicking on perfomance.
here ist the encrypted error. I have no glue what to do.
I thought maybe a update to version 1.1 to solve this problem, but i can´t cause i get this damn error..
Thanks a lot
Now the encrypted error:
## ThirtyBeesException
**Call to undefined method GuzzleHttp\Client::getAsync()**
 *at line* **1093** *in file* `classes/module/Module.php`
```php
1088.                        'url'                 => isset($module['url']) ? $module['url'] : '',
1089.                    ];
1090.
1091.                    if (isset($module['img'])) {
1092.                        if (!file_exists(_PS_TMP_IMG_DIR_.md5($name).'.png')) {
1093. =>                         $imagePromises[$name] = $guzzle->getAsync($module['img'], ['sink' => _PS_TMP_IMG_DIR_.md5($name).'.png']);
1094.                        }
1095.
1096.                        $item['image'] = '../img/tmp/'.md5($name).'.png';
1097.                    }
1098.
- **ModuleCore::getModulesOnDisk** - [line `334` - `controllers/admin/AdminModulesController.php`]
 - [3 Arguments]
```php
329.                }
330.                $modulesPreferences[$v['module']] = $v;
331.            }
332.
333.            // Retrieve Modules List
334. =>         $modules = Module::getModulesOnDisk(true, $this->logged_on_addons, $this->id_employee);
335.            $this->initModulesList($modules);
336.            $this->nb_modules_total = count($modules);
337.            $moduleErrors = [];
338.            $moduleSuccess = [];
339.            $upgradeAvailable = [];
```Argument [0]
1
Argument [1]
Argument [2]
2
- **AdminModulesControllerCore->initContent** - [line `262` - `classes/controller/Controller.php`]
```php
257.                if (!$this->content_only && ($this->display_header || (isset($this->className) && $this->className))) {
258.                    $this->initHeader();
259.                }
260.
261.                if ($this->viewAccess()) {
262. =>                 $this->initContent();
263.                } else {
264.                    $this->errors[] = Tools::displayError('Access denied.');
265.                }
266.
267.                if (!$this->content_only && ($this->display_footer || (isset($this->className) && $this->className))) {
- **ControllerCore->run** - [line `837` - `classes/Dispatcher.php`]
```php
832.                if (isset($paramsHookActionDispatcher)) {
833.                    Hook::exec('actionDispatcher', $paramsHookActionDispatcher);
834.                }
835.
836.                // Running controller
837. =>             $controller->run();
838.            } catch (PrestaShopException $e) {
839.                $e->displayMessage();
840.            }
841.        }
842.
- **DispatcherCore->dispatch** - [line `63` - `admin/index.php`]
```php
58.    if (!isset($_REQUEST['controller']) && isset($_REQUEST['tab'])) {
59.        $_REQUEST['controller'] = strtolower($_REQUEST['tab']);
60.    }
61.
62.    // Prepare and trigger admin dispatcher
63. => Dispatcher::getInstance()->dispatch();
7 answers to this question
  • 1
module TBUpdater causes the crash..  when took out of modules directory .. module listing works again..need to understand why, but have no more time right now..
The back office works again now.
  • Thanks 1
Looks like you have outdated guzzle library.
First, check that your /vendor directory is up to date -- download thirtybees install zip file, extract it, and upload /vendor directory to your server.
If this doesn't help, then the only explanation is that there's some module that comes with its own version of guzzle library, and this somehow overrides the default guzzle library that comes with thirtybees.
Nice tip, I also proposed my help to check it on the server, but seems like You gave him the good direction to solve it alone,
Edited by zen
I wouldn't be so sure this module was the root cause, it's possible it is just a red herring.
From stacktrace, it's obvious that thirtybees is trying to download logo for some module from thirtybees repository. It is quite possible that it was 'tbupdater' module for which the logo image was being downloaded. If that's the case, then deletion of this module would hide the problem. But not solve it -- it might still be there, patiently waiting for another chance to manifest.
I'd suggest additional investigation.
Of course !!
The hosting could be and seems to be the root problem here.
The shop is working. apparently good now and updated on the 1.1.0 version with success 🙂
thanks to this thread :
but maybe more problems to come ... hosting is an important factor for the success of your eshop !
