oneall.com Module
Please could I have a bit of help here .. I have used this module for as long as I can remember.. It's been on the back burner for while now and am finally getting around to look into it.
I already have Facebook log in working correctly and logs me in fine.But it is not the case with Twitter, Everything works fine except when it comes to redirecting but to my page I get the error message below with a 500 page.
Now being nosy I read into on line 161 expect a 1, so I went there and found Tools::redirect ( ); so I tried making it (1 ); .. It got me past the 500 page but to a not found product page and it hadn't signed me in either.
So am hoping someone here can help if at all possible
Decoded exception
Too few arguments to function ToolsCore::redirect(), 0 passed in /home/edit out/public_html/modules/oneallsociallogin/controllers/front/register.php on line 161 and at least 1 expected
in file classes/Tools.php at line 218
Source file: classes/Tools.php
199:            }
200:
201:            $result .= sha1($entropy, true);
202:        }
203:
204:        return substr($result, 0, $length);
205:    }
206:
207:    /**
208:     * Redirect user to another page
209:     *
210:     * @param string       $url     Desired URL
211:     * @param string       $baseUri Base URI (optional)
212:     * @param Link         $link
213:     * @param string|array $headers A list of headers to send before redirection
214:     *
215:     * @since   1.0.0
216:     * @version 1.0.0 Initial version
217:     */
218:    public static function redirect($url, $baseUri = __PS_BASE_URI__, Link $link = null, $headers = null)
219:    {
220:        if (!$link) {
221:            $link = Context::getContext()->link;
222:        }
223:
224:        if (strpos($url, 'http://') === false && strpos($url, 'https://') === false && $link) {
225:            if (strpos($url, $baseUri) === 0) {
226:                $url = substr($url, strlen($baseUri));
227:            }
228:            if (strpos($url, 'index.php?controller=') !== false && strpos($url, 'index.php/') == 0) {
Thanks
The code we have just fixed is in the error execution branch (unfortunately). Which means that either line
        if (isset($this->context->cookie->oasl_data))
or lines
            // Extract the data.
            $data = json_decode($this->context->cookie->oasl_data, true);
            // Check data format.
            if (is_array($data))
evaluated to false.
This is not a technical issue, but business-logic issue. This variable is either not set, or contains invalid content. Either way, you should definitely report this to the module developer. This won't be easy to fix, without deep knowledge of module design and data flow.
I fully understand, I was hoping it would be a simple fix ...So thank you for all your help anyway.. I'll have to get back onto them for help.
