I get the following error displayed for the cart using Bleeding Edge 1.1.x for a shop that works fine with 1.1.0 Stable.
The product selection cannot be delivered by the available carrier(s): it is too heavy. Please amend your cart to lower its weight.
I'm using a the Community Theme Default that I've modified and have some overrides. This error is displayed with the overrides turned off and the cache cleared.
If developers would like me to investigate, please post what you would like to see and I can run tests and posts results. It isn't a problem for me because the shop works fine with the 1.1.0 stable release. I was just trying the bleeding edge release.
Rhapsody
Edited by RhapsodyLink to comment
2 answers to this question
