d3s1gn3r Posted May 8, 2020 Posted May 8, 2020 I m not quite sure if this is the right place to post this question but i would like to ask with which version of Prestashop is 30bees compatible for both themes and modules. 1.6 or 1.7 ??? Thanks in advance.
0 datakick Posted May 8, 2020 Posted May 8, 2020 22 minutes ago, d3s1gn3r said: I m not quite sure if this is the right place to post this question but i would like to ask with which version of Prestashop is 30bees compatible for both themes and modules. 1.6 or 1.7 ??? Thanks in advance. Thirtybees is continuation of ps16, and should be backwards compatible with it. That means, most of ps16 modules will work on thirtybees. But thirtybees modules might not work on ps16. Ps17 is completely different beast. It's not compatible with neither ps16, nor thirtybees. ps17 is often not compatible with ps17 itself 🙂 Stay away from it. 1 1
0 d3s1gn3r Posted May 8, 2020 Author Posted May 8, 2020 @datakick thanks for your answer. Now it makes more sense to me why 30bees is way much better than Prestashop. Actually i will stick for sure with 30bees only. Almost only 3-4 days working with it and i have to say that i love it. Clean code, Fast Back End, Easy to use. Now i build my own theme 😉
0 toplakd Posted May 8, 2020 Posted May 8, 2020 (edited) 1 hour ago, datakick said: ps17 is often not compatible with ps17 itself That's the best comment ever on this forum. 🤣 Edited May 8, 2020 by toplakd 2
d3s1gn3r
Thanks in advance.
3 answers to this question
