Stripe Module Validation Failed
Hi,
We have installed stripe module and testing it in in the test mode. During checkout it redirect to stripe website to enter the credit card information and stripe is successfully complete the transaction. Once the transaction is completed and returns back to TB, it shows "Failed to validate order"
we checked in stripe module> Stripe Transaction tab it shows "Charge Failed"
Any ideas, how to fix this issue?
  • Like 2
15 answers to this question
Has anyone else found a solution?
I got this error message after ordering myself something with a live card. The card was charged and the order shows in the back office. The same thing happened to a customer this morning.
I'm on bleeding edge version 1.3 and PHP 8.
Edited by veganline
version
Still failing on version 1.2 and PHP 7.4 unfortunately.
Stripe shows the payment initially "incomplete", which I suppose triggers the error, and then as complete.
It might be relevant that my email notifications haven't worked since late September; I don't know what I did to break them.
---added
The Stripe site has an error message next to the first failed payment
The PaymentIntent requires a payment method
Set an existing payment method on the PaymentIntent or have the customer enter a new payment method.
Learn more"
Then a couple of seconds later, the payment goes-through after triggering the error message.
If you click on the links to find out more, your find a blank page on the Stripe site.
---added
After changing back to 1.7.0 and forward again to 1.7.1 I get a different error message in black under the inline Stripe form:
No such payment_intent: 'pi_3JklsDGngIXhdSwB05cBtIoo'; a similar object exists in live mode, but a test mode key was used to make this request.
Edited by veganline
Looks like when you updated module, its configuration was reset, and it's back in testing mode. The payment intent is stored in cookie, and is no longer valid.
Please check module configuration and switch it to live mode, if that's what you are testing. Also, clear browser cache / cookies.
Thanks! The payment worked, but the screen took me to
Example.com/module/stripe/validation?type=cc headed "payment error". I suppose I could change it somehow. It shows this error message and a button to go back to the shopping cart
 An error occurred:
  • Failed to validate order
The root cause is well hidden... this module does excellent job hiding everything important from everybody
Edit file modules/stripe/classes/PaymentProcessor.php, find line
this->addError($this->l('Failed to validate order'), (string)$e);
and change it to look like this:
d("$e");
$this->addError($this->l('Failed to validate order'), (string)$e);
The d("$e") should display additional information when error happen. Hopefully we can use this info to figure out what's actually wrong
Swift_RfcComplianceException: Address in mailbox given [] does not comply with RFC 2822, 3.6.2. in /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/Headers/MailboxHeader.php:345 Stack trace: #0 /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/Headers/MailboxHeader.php(261): Swift_Mime_Headers_MailboxHeader->_assertValidAddress('') #1 /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/Headers/MailboxHeader.php(106): Swift_Mime_Headers_MailboxHeader->normalizeMailboxes(Array) #2 /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/Headers/MailboxHeader.php(63): Swift_Mime_Headers_MailboxHeader->setNameAddresses(Array) #3 /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/SimpleMimeEntity.php(592): Swift_Mime_Headers_MailboxHeader->setFieldBodyModel(Array) #4 /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/SimpleMessage.php(432): Swift_Mime_SimpleMimeEntity->_setHeaderFieldModel('Bcc', Array) #5 /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/SimpleMessage.php(412): Swift_Mime_SimpleMessage->setBcc(Array) #6 /home/veganlin/public_html/classes/Mail.php(293): Swift_Mime_SimpleMessage->addBcc(NULL) #7 /home/veganlin/public_html/modules/mailalerts/mailalerts.php(702): MailCore::Send(1, 'new_order', 'new order: #168...', Array, 'shop@veganline....', '', 'shop@veganline....', 'Veganline.com', NULL, NULL, '/home/veganlin/...', NULL, 1) #8 /home/veganlin/public_html/classes/Hook.php(769): MailAlerts->hookActionValidateOrder(Array) #9 /home/veganlin/public_html/classes/Hook.php(471): HookCore::coreCallHook(Object(MailAlerts), 'hookactionValid...', Array) #10 /home/veganlin/public_html/classes/Hook.php(288): HookCore::execWithoutCache('actionValidateO...', Array, NULL, false, true, false, NULL) #11 /home/veganlin/public_html/classes/module/PaymentModule.php(967): HookCore::exec('actionValidateO...', Array) #12 /home/veganlin/public_html/modules/stripe/classes/PaymentProcessor.php(208): PaymentModuleCore->validateOrder(431, 1, 1.51, 'Stripe: Credit ...', NULL, Array, NULL, false, '98dc27777291456...') #13 /home/veganlin/public_html/modules/stripe/classes/PaymentProcessor.php(116): StripeModule\PaymentProcessor->processCharge(Object(Cart), Object(ThirtyBeesStripe\Stripe\Charge), Object(ThirtyBeesStripe\Stripe\PaymentIntent)) #14 /home/veganlin/public_html/modules/stripe/controllers/front/validation.php(153): StripeModule\PaymentProcessor->processPayment(Object(Cart), Object(ThirtyBeesStripe\Stripe\PaymentIntent)) #15 /home/veganlin/public_html/modules/stripe/controllers/front/validation.php(127): StripeValidationModuleFrontController->processPayment(Object(Cart), Object(ThirtyBeesStripe\Stripe\PaymentIntent)) #16 /home/veganlin/public_html/modules/stripe/controllers/front/validation.php(98): StripeValidationModuleFrontController->processPaymentIntent('pi_3Jknq0GngIXh...') #17 /home/veganlin/public_html/modules/stripe/controllers/front/validation.php(59): StripeValidationModuleFrontController->validateCreditCard() #18 /home/veganlin/public_html/classes/controller/Controller.php(197): StripeValidationModuleFrontController->postProcess() #19 /home/veganlin/public_html/classes/controller/FrontController.php(255): ControllerCore->run() #20 /home/veganlin/public_html/classes/Dispatcher.php(852): FrontControllerCore->run() #21 /home/veganlin/public_html/index.php(33): DispatcherCore->dispatch() #22 {main}
END
Might be relevant: I have some override files. I do not know where they came from.
AuthController.php
33.4 KB
Today, 12:10 PM
OrderOpcController.php
39 KB
Today, 12:10 PM
ContactController.php
   3.1 KB
Sep 17, 2021
Swift_RfcComplianceException: Address in mailbox given [] does not comply with RFC 2822, 3.6.2. in /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/Headers/MailboxHeader.php:345 Stack trace: #0 /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/Headers/MailboxHeader.php(261): Swift_Mime_Headers_MailboxHeader->_assertValidAddress('') #1 /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/Headers/MailboxHeader.php(106): Swift_Mime_Headers_MailboxHeader->normalizeMailboxes(Array) #2 /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/Headers/MailboxHeader.php(63): Swift_Mime_Headers_MailboxHeader->setNameAddresses(Array) #3 /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/SimpleMimeEntity.php(592): Swift_Mime_Headers_MailboxHeader->setFieldBodyModel(Array) #4 /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/SimpleMessage.php(432): Swift_Mime_SimpleMimeEntity->_setHeaderFieldModel('Bcc', Array) #5 /home/veganlin/public_html/vendor/swiftmailer/swiftmailer/lib/classes/Swift/Mime/SimpleMessage.php(412): Swift_Mime_SimpleMessage->setBcc(Array) #6 /home/veganlin/public_html/classes/Mail.php(293): Swift_Mime_SimpleMessage->addBcc(NULL) #7 /home/veganlin/public_html/classes/module/PaymentModule.php(1099): MailCore::Send(1, 'order_conf', 'automatic ackno...', Array, 'shop@veganline....', 'John Robertson', 'shop@veganline....', 'Veganline.com', NULL, NULL, '/home/veganlin/...', false, 1) #8 /home/veganlin/public_html/modules/stripe/classes/PaymentProcessor.php(208): PaymentModuleCore->validateOrder(434, 1, 1.51, 'Stripe: Credit ...', NULL, Array, NULL, false, '98dc27777291456...') #9 /home/veganlin/public_html/modules/stripe/classes/PaymentProcessor.php(116): StripeModule\PaymentProcessor->processCharge(Object(Cart), Object(ThirtyBeesStripe\Stripe\Charge), Object(ThirtyBeesStripe\Stripe\PaymentIntent)) #10 /home/veganlin/public_html/modules/stripe/controllers/front/validation.php(153): StripeModule\PaymentProcessor->processPayment(Object(Cart), Object(ThirtyBeesStripe\Stripe\PaymentIntent)) #11 /home/veganlin/public_html/modules/stripe/controllers/front/validation.php(127): StripeValidationModuleFrontController->processPayment(Object(Cart), Object(ThirtyBeesStripe\Stripe\PaymentIntent)) #12 /home/veganlin/public_html/modules/stripe/controllers/front/validation.php(98): StripeValidationModuleFrontController->processPaymentIntent('pi_3JkooXGngIXh...') #13 /home/veganlin/public_html/modules/stripe/controllers/front/validation.php(59): StripeValidationModuleFrontController->validateCreditCard() #14 /home/veganlin/public_html/classes/controller/Controller.php(197): StripeValidationModuleFrontController->postProcess() #15 /home/veganlin/public_html/classes/controller/FrontController.php(255): ControllerCore->run() #16 /home/veganlin/public_html/classes/Dispatcher.php(852): FrontControllerCore->run() #17 /home/veganlin/public_html/index.php(33): DispatcherCore->dispatch() #18 {main}
END
Edited by veganline
overrides
The root cause is here:
The system is adding null BCC address. Now, the question is why.
  • Do you have some module that hooks to hook actionEmailSendBefore?
  • check BCC all mails to configuration option in Advanced Parameters > Emails
  • can you PM me access to your back office?
You've solved it!
I had BCC all emails turned-on under Advanced Parameters > Emails
When I turned it off, the error message was gone.
I'll PM access to the back office in case there is anything you're curious about.
8 minutes ago, veganline said:
You've solved it!
Still weird. The controller code verifies that the list of bcc addresses is valid, this should not result with null item. I tried to reproduce the issue, but without success...
Quote
Is there a way to test for this? The
"An error occured:
  • failed to validate order"
problem  on Stripe has returned unfortunately
"An error occured: * failed to validate order" problem on Stripe has returned unfortunately
eMagicOne Store Manager Bridge Connector, version 3.0.13 - by eMagicOne was the problem
The Storemanager system doesn't update automatically but there is a current module for PS1.6:
eMagicOne Store Manager Bridge Connector, v3.1.7 - by eMagicOne
Storemanager was a way of tweaking the store data from a separate screen, which claimed to have an add-on that could synchronize Prestashop 1.6 and Ebay. That's why I bought the thing dispite never getting it to work. There was also an android app that could read your back office apparently, but I can't make it work today.
...has the same problem. I am using Thirtybees 1.6.0 on PHP 8.0.30 with no regular error messages except
I forgot that I had the module as I have never managed to make the thing work, so turning it off is no problem. I'm just adding detail for reference in case anyone else finds the same thing
Error logs included a notice from about the time I installed the updated module
Message:  Only variables should be passed by reference
Location: modules/bridgeconnector/functions/for_ajax.php line 308
I can pass-on more detail if anyone is interested.
Edited by veganline
