Madbits Posted September 9, 2020 Posted September 9, 2020 Whenever I visit categories I notice that their title is as follows: Category - Shop Name - Short Shop Name I already add my shops name in meta titles and I do not need the last "- Casablanca". I also edited classes/Meta.php and removed pretty much all " . '-' . meta::titlewhatever('shopnamewhatever') ". Kind regards!
1 veganline Posted September 13, 2020 Posted September 13, 2020 (edited) Same here - any ideas welcome Edited September 13, 2020 by veganline
0 veganline Posted September 10, 2020 Posted September 10, 2020 (edited) remove " - shopname" from category titles - has anyone found how? I tried the same idea of removing anything likely from classes/Meta.php without luck Edited September 10, 2020 by veganline
0 datakick Posted September 10, 2020 Posted September 10, 2020 You need to edit Meta.php, method getCategoryMetas, lines ~ 443-449 https://github.com/thirtybees/thirtybees/blob/21b15c3e17188037e4862ddf357b6a3d65f1c3bd/classes/Meta.php#L443-L449 There are three similar lines looking like this: $row['meta_title'] = $title.$row['meta_title'].(!empty($pageNumber) ? ' ('.$pageNumber.')' : '').' - '.Configuration::get('PS_SHOP_NAME'); You want to edit these lines to look like this: $row['meta_title'] = $title.$row['meta_title'].(!empty($pageNumber) ? ' ('.$pageNumber.')' : ''); 2
0 Madbits Posted September 10, 2020 Author Posted September 10, 2020 5 hours ago, datakick said: You need to edit Meta.php, method getCategoryMetas, lines ~ 443-449 https://github.com/thirtybees/thirtybees/blob/21b15c3e17188037e4862ddf357b6a3d65f1c3bd/classes/Meta.php#L443-L449 There are three similar lines looking like this: $row['meta_title'] = $title.$row['meta_title'].(!empty($pageNumber) ? ' ('.$pageNumber.')' : '').' - '.Configuration::get('PS_SHOP_NAME'); You want to edit these lines to look like this: $row['meta_title'] = $title.$row['meta_title'].(!empty($pageNumber) ? ' ('.$pageNumber.')' : ''); This is how I already had them. 🙂
0 Madbits Posted September 22, 2020 Author Posted September 22, 2020 (edited) On 9/13/2020 at 3:35 PM, veganline said: Same here - any ideas welcome {assign var=_title value=" - $shop_name"} <title>{$meta_title|replace:$_title:' - Your Shop Name'|escape:'htmlall':'UTF-8'}</title> This is what I'm using to fix this issue, it will replace any shops name that will be generated in a title with the one you specifie in ' - Your Shop Name'. Hope it helps. 🙂 Use it in your header.tpl Edited October 20, 2020 by Madbits 1
0 veganline Posted May 30, 2025 Posted May 30, 2025 (edited) New Free Module: Remove Shop Name in Meta Title - the link is to a Chatgpt page https://chatgpt.com/share/683999c5-e6d4-8003-a150-5d00e8ca6c4b ... which has a Zip file to download at the bottom. Tested very briefly on Thirtybees 1.6 using PHP 8 with no deathplunge drama yet. Edited June 8, 2025 by veganline edited the linked-to page
Madbits
Kind regards!
6 answers to this question
