What kind of modules, integrations or other third party software do you use to keep track of stock value?
Is there any out there which do have a working integration to Thirtybees that can handle movement in stock and fifo for example?
Seems like that's more to keep track of lot and serials?
Is it possible for example to get a report of the total stock value at a given date?
Does it also use fifo and keep track of deliveries and purchase orders?
I need this for my accounting.
Yep, it keeps track of lots via FIFO and you can also state when something entered your stock. You can't get a report of stock at a given date, though. It's rather cumbersome. Probably not the best for your needs.
