Products linked as combinations - Module suggestion
This looks like a very simple module. It simply allows you to link several products together, and display these linked products on product page, under the name 'Variants'
It works quite like build-in Accessories feature. Accessories are just rendered in their own tab, and as a product miniature. With a little bit of theme modification you could actually use the Accessories feature to accomplish this module's functionality.
I got it, and Datakick just gave a simple solution to do it, it so much like the accessories feature, 100% agree !
It dosen't work like the Accessories feature.
The good thing about the module is that, when you add a link to a product, that same link is added vice versa on the product you add the link to. And if you delete a link from one of them, it gets deleted both ways. In that way, if you have 5 products you want to link, you dont need to associate the products 5 times on 5 products - but rather only on one product - and then it adds it vice versa on all the 5 other products.
Edited by Bull
