alwayspaws Posted February 28, 2017 Posted February 28, 2017 PS 1.6.1.11 How can I create products with combinations and upload them via CSV? I have images uploaded and online for these products. Thanks!
0 alwayspaws Posted March 6, 2017 Author Posted March 6, 2017 Thank you. That looks great! I think I completely misunderstood something. I thought I did not have to type in all those combinations manually. I thought the .csv would create them automatically. Is this right or wrong? I had trouble incrementing the numbers with a dash in openoffice calc, but it works in MS Excel for Mac. One thing is going right!
0 spidawebs Posted March 6, 2017 Posted March 6, 2017 @alwayspaws No the csv file will not create the combinations automatically, you need to enter them yourself but it really doesn't take long as you can drag the cells down to copy of lot of it and use copy/paste or find/replace where you have to. In openoffice you need to create two references and then drag the columns down and then it will automatically carry on the sequence. eg, enter 1000-1 1000-2 then highlight both cells and drag them down
0 alwayspaws Posted March 6, 2017 Author Posted March 6, 2017 I see about the cells. Thanks. About copying and pasting seven to eleven colors and seven sizes in the same column, I'm a little confused. I copied and pasted everything already except the combinations values.
0 alwayspaws Posted March 6, 2017 Author Posted March 6, 2017 @spidawebs Just to check, I am to manually enter XS (8);aqua and so on, for every size and color? BTW, I'm going to change that size attribute. It's too complicated.
0 spidawebs Posted March 6, 2017 Posted March 6, 2017 @alwayspaws What I do is put all the sizes in first with a semi colon such as this: small; medium; large; copy and paste those all the way down (7 times if you have 7 different colours) then you just need to add the colours after the semi colon. That way you could do 100 combinations in about a minute.
0 alwayspaws Posted March 6, 2017 Author Posted March 6, 2017 @spidawebs I'm going to do that right now, after I fix the sizes to something normal. Thank you!
0 alwayspaws Posted March 7, 2017 Author Posted March 7, 2017 @spidawebs I created a new csv with products and combinations info together. Everything went well until I tried to import and match up the combinations fields. These are the available fields in my admin: https://www.alwayspaws.com/images/available-fields-for-combinations-csv-import.jpg The combinations column headers are not available as shown here: https://www.alwayspaws.com/images/combinations-import-column-headers-not-there.jpg Separate question: Also, regarding the products import screenshot, you have "force all ID numbers" as yes. Do I need to do this? Thanks so much. (I'm sorry but I don't see where to add hyperlinks to my sentences). I'm using PS 1.6.1.11 now.
0 spidawebs Posted March 7, 2017 Posted March 7, 2017 @alwayspaws You need to do two imports. Firstly one for products. Match up all the columns required for new products and select ignore if they are relating to combinations. Then do another import for the combinations, this time select all the columns related to the combinations and ignore the ones related to new products. Once I have the fields all match I save each one (one for new products, one for combinations) so I don't have to keep manually selecting the headers everytime I do an import. Yes, you need to force all ID numbers so they import as in your spreadsheet. Otherwise PS may generate different ones and nothing will match up.
0 alwayspaws Posted March 7, 2017 Author Posted March 7, 2017 @spidawebs i understand but how can I match my fields if they're not in the combinations available field section in Admin? Thank you!
0 spidawebs Posted March 7, 2017 Posted March 7, 2017 They are there, they are just called something slightly different to the spreadsheet. So "Combinations Reference" is "Reference", Combination Name is "Attribute (Name:Type:Position)" etc etc
0 alwayspaws Posted March 7, 2017 Author Posted March 7, 2017 @spidawebs oh, I see. I was looking for exact matches. I also noticed that you have a blank or an empty field heading in the screenshot and I'm wondering how you can do that please?
0 alwayspaws Posted March 7, 2017 Author Posted March 7, 2017 Can I change the topic of this post? It has nothing to do with store commander.
0 spidawebs Posted March 7, 2017 Posted March 7, 2017 I'm not sure how that happened in the screenshot as it shouldn't be possible! If you don't want to use a column you just need to select "Ignore this column". Yes, good idea, change it to something more relevant!
0 alwayspaws Posted March 7, 2017 Author Posted March 7, 2017 @spidawebs I understand. The topic name has been changed. Thank you for the help!
0 alwayspaws Posted March 9, 2017 Author Posted March 9, 2017 @spidawebs Hi! I didn't disappear. I perfectly (afaik) formatted my product and combinations spreadsheet from all the instructions and screenshots you provided, for only one item. I've been trying for two days to upload my product csv but have been having the "500 - Internal Server Error" and have been in touch with my host who did this: "increased the maximum execution time and the PHP memory limit to the maximum value allowed to see if this makes any difference". It did not make any difference, so I contacted them again and gave them the screenshot of the errors. I also researched it on the PS Forums: 500 Internal Server Error on CSV Import https://www.prestashop.com/forums/topic/151212-500-internal-server-error-on-csv-import/page-2?hl=+500%20+internal%20+server%20+error The reply and fix for them was: "In Performance change cache option. There are two options. Don't cache every change in files." I did all the following and still am getting the 500 Internal Server Error: Template compilation is set to "recompile templates if the files have been updated". Turned off SMARTY cache. All CCC is set to NO. Bottom of Performance screen: Caching - use cache - I set it to NO. I turned Apache optimization off. Tried a different browser. No change. I'm posting this in the PS Forum in hopes they have an answer. As soon as I have success, I'll let you know. I appreciate your help very much!
0 spidawebs Posted March 9, 2017 Posted March 9, 2017 Can you go to Advanced Parameters > Configuration Information and look under server information. I have my server set to the following which works fine for me: Memory limit 1024M Max execution time 2880
0 alwayspaws Posted March 9, 2017 Author Posted March 9, 2017 I can't see where to change it but here is what it shows. Way below what you have! Server information Linux #12 SMP Wed Sep 28 11:31:36 EEST 2016 x86_64 Server software version Apache PHP version 7.0.16 Memory limit 768M Max execution time 120 I want to change this! Also on that page: CHECK YOUR CONFIGURATION Required parameters OK Optional parameters OK LIST OF CHANGED FILES - this may be because I changed hosts two months ago: Changed/missing files have been detected. Missing files (977) adminQy7e=WJ/ajax-tab.php adminQy7e=WJ/ajax.php adminQy7e=WJ/ajaxproductslist.php adminQy7e=WJ/backup.php adminQy7e=WJ/croncurrencyrates.php adminQy7e=WJ/displayImage.php adminQy7e=WJ/drawer.php adminQy7e=WJ/footer.inc.php adminQy7e=WJ/functions.php Do you have to upload images to your server before you can put them in messages here? I wanted to include the screenshot.
0 alwayspaws Posted March 9, 2017 Author Posted March 9, 2017 I'm researching: "change server information in prestashop 1.6 admin" and"change server information in prestashop 1.6". I'm getting nowhere fast. I need to leave for a bit (even though I don't want to!) but FYI I use sublime and know how to edit .tpl files, etc.
0 Havouza Posted March 9, 2017 Posted March 9, 2017 @spidawebs sorry to jump in but do the server really cope with that max execution time?
0 spidawebs Posted March 9, 2017 Posted March 9, 2017 @alwayspaws said in Importing Products and Combinations with csv's: Memory limit 768M Max execution time 120 You need to ask your server host to change the memory limit and max execution time in your php.ini file
0 spidawebs Posted March 9, 2017 Posted March 9, 2017 @Havouza Yes, why, what do you suggest it should be?
0 alwayspaws Posted March 9, 2017 Author Posted March 9, 2017 @spidawebs said in Importing Products and Combinations with csv's: @alwayspaws said in Importing Products and Combinations with csv's: Memory limit 768M Max execution time 120 You need to ask your server host to change the memory limit and max execution time in your php.ini file @spidawebs I will do that right now. Thank you!
0 alwayspaws Posted March 9, 2017 Author Posted March 9, 2017 @spidawebs said in Importing Products and Combinations with csv's: @alwayspaws said in Importing Products and Combinations with csv's: Memory limit 768M Max execution time 120 You need to ask your server host to change the memory limit and max execution time in your php.ini file I'll do that right now. Thanks!
0 Havouza Posted March 9, 2017 Posted March 9, 2017 No but wherever you read more then 300 sec (5 min) is hard for the server. I have one shop with quite a lot of traffic that runs on 128 mb memory and 300 sec without any issues
alwayspaws
PS 1.6.1.11
Thanks!
Top Posters For This Question
28
16
11
1
Popular Days
Mar 9
16
Mar 6
10
Mar 3
10
Mar 7
8
alwayspaws 28 posts
spidawebs 16 posts
Havouza 11 posts
crosscut01 1 post
Popular Days
Mar 9 2017
Mar 6 2017
Mar 3 2017
Mar 7 2017
56 answers to this question
