alwayspaws Posted February 28, 2017 Posted February 28, 2017 PS 1.6.1.11 How can I create products with combinations and upload them via CSV? I have images uploaded and online for these products. Thanks!
0 spidawebs Posted March 9, 2017 Posted March 9, 2017 @Havouza I regularly have to import files which take longer than 5 minutes. This setting seems to work fine for me. It took me ages to find a value where it wouldn't time out.
0 Havouza Posted March 9, 2017 Posted March 9, 2017 OK. I import an image file from the supplier directly to the webserver three times a week. The file is around 1Gb and take max 25 second
0 spidawebs Posted March 9, 2017 Posted March 9, 2017 @Havouza Wow, that's quick. My product import files are usually only about 300KB but they take ages to import if there are lots of products and combinations. I also needed that setting for the Amazon module we use as it wouldn't work previously until I changed to these settings.
0 Havouza Posted March 9, 2017 Posted March 9, 2017 If I had to first download them to my local computer and then upload them to the webserver it would take ages with my 768 kb upload but this way it is lightning fast
0 alwayspaws Posted March 9, 2017 Author Posted March 9, 2017 I had trouble with the timeout because I was trying to import images in my product.csv.
0 Billy Posted April 27, 2019 Posted April 27, 2019 (edited) On 3/3/2017 at 1:58 AM, spidawebs said: 01488524146618New Product Import.csv Attached is an example of the csv file I use incase it is of use. Just open in Excel and edit. The columns in white are the fields I import using the products csv import, the ones in yellow I import using the combinations csv import. When importing the combination just made sure you use the ID field so the products are matched. @spidawebs anyway you could reattach your .csv example file? The forum won't allow me access to it. TIA _Bill Edited April 27, 2019 by Script-Fu
alwayspaws
PS 1.6.1.11
Thanks!
Top Posters For This Question
28
16
11
1
Popular Days
Mar 9
16
Mar 6
10
Mar 3
10
Mar 7
8
alwayspaws 28 posts
spidawebs 16 posts
Havouza 11 posts
crosscut01 1 post
Popular Days
Mar 9 2017
Mar 6 2017
Mar 3 2017
Mar 7 2017
56 answers to this question
