jn1 Posted January 17, 2023 Posted January 17, 2023 Hello I will get the following errors after I have update to 1.4 unsing php 8.0. any ideas where I should start to find the problems. Best wishes Josef Error Attempt to modify property "value" on null when rendering smarty template /mnt/web306/e3/87/52118087/htdocs/ptsv/presta1_6/thirtybees/themes/ptsvshop-template/modules/blockcart/blockcart.tpl  vendor/smarty/smarty/libs/sysplugins/smarty_template_resource_base.php:123 source content_63c68dcfd19537_45880373() 2. vendor/smarty/smarty/libs/sysplugins/smarty_template_compiled.php:114 source Smarty_Template_Resource_Base->getRenderedTemplateCode() 3. vendor/smarty/smarty/libs/sysplugins/smarty_internal_template.php:216 source Smarty_Template_Compiled->render() 4. vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php:238 source Smarty_Internal_Template->render() 5. vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php:116 source Smarty_Internal_TemplateBase->_execute() 6. classes/SmartyCustom.php:555 source Smarty_Internal_TemplateBase->fetch() 7. classes/SmartyCustom.php:530 source Smarty_Custom_Template->fetchWithRetries() 8. classes/module/Module.php:3170 source Smarty_Custom_Template->fetch() 9. modules/blockcart/blockcart.php:251 source ModuleCore->display() 10. modules/blockcart/blockcart.php:488 source BlockCart->hookRightColumn() 11. classes/Hook.php:769 source BlockCart->hookTop() 12. classes/Hook.php:473 source HookCore::coreCallHook() 13. classes/Hook.php:288 source HookCore::execWithoutCache() 14. classes/controller/FrontController.php:346 source HookCore::exec() 15. controllers/front/IndexController.php:53 source FrontControllerCore->initContent()
0 datakick Posted January 17, 2023 Posted January 17, 2023 Your theme contains override for blockcart.tpl template. You will have to update it to be compatible with PHP8. Look here for inspiration:Â https://github.com/thirtybees/niara/commit/1f9629157606620748b3b5e769d621d9ccdfc751
0 jn1 Posted January 17, 2023 Author Posted January 17, 2023 Thanks, datakick, I am bit lost. I do not know where I should/can start debugging. Best wishes Josef
0 datakick Posted January 17, 2023 Posted January 17, 2023 Ftp to your server, edit file /themes/ptsvshop-template/modules/blockcart/dropdown.tpl and look for line {assign var='free_ship' value=count($cart->getDeliveryAddressesWithoutCarriers(true, $errors))} or something similar to it Change it to look like this: {assign var='free_ship' value=count($cart->getDeliveryAddressesWithoutCarriers(true))} What has to be changed is highlighted in the link I posted above.
0 jn1 Posted January 18, 2023 Author Posted January 18, 2023 you are a genius. It worked. Thank you very much. Overall, it seems that the upgrade worked quite good. I just have one problem with an external module, which is for exporting orders. I would be glad to hear about good and free alternatives 😉 Best wishes Josef
0 Oncle Posted May 1, 2023 Posted May 1, 2023 Hello, I have done what is said: Change it to look like this: {assign var='free_ship' value=count($cart->getDeliveryAddressesWithoutCarriers(true))} But after a while I got this other error: Attempt to modify property "value" on null when rendering smarty template /themes/community-theme-default/./breadcrumb.tpl Any suggestions? Thanks
0 312erik123 Posted June 5, 2023 Posted June 5, 2023 On 5/1/2023 at 7:42 PM, Oncle said: Hello, I have done what is said: Change it to look like this: {assign var='free_ship' value=count($cart->getDeliveryAddressesWithoutCarriers(true))} But after a while I got this other error: Attempt to modify property "value" on null when rendering smarty template /themes/community-theme-default/./breadcrumb.tpl Any suggestions? Thanks Have the same issue - did you manage to solve it?
0 e-com Posted June 6, 2023 Posted June 6, 2023 15 hours ago, 312erik123 said: Have the same issue - did you manage to solve it? Copy code of breadcrumb.tpl into your theme: https://github.com/thirtybees/community-theme-default/blob/1.1.x/breadcrumb.tpl  1
0 312erik123 Posted June 6, 2023 Posted June 6, 2023 17 hours ago, e-com said: Copy code of breadcrumb.tpl into your theme: https://github.com/thirtybees/community-theme-default/blob/1.1.x/breadcrumb.tpl  Thanks! Works!
0 30knees Posted June 7, 2023 Posted June 7, 2023 On 1/18/2023 at 6:40 AM, jn1 said: I just have one problem with an external module, which is for exporting orders. I would be glad to hear about good and free alternatives 😉 Might this help? Â
0 Oncle Posted June 9, 2023 Posted June 9, 2023 On 6/6/2023 at 5:50 AM, e-com said: Copy code of breadcrumb.tpl into your theme: https://github.com/thirtybees/community-theme-default/blob/1.1.x/breadcrumb.tpl  Thanks! It works by copying the code.
jn1
Hello
Best wishes
Josef
10 answers to this question
