vzex Posted August 1, 2017 Share Posted August 1, 2017 Fresh install added productcomments module can leave review approve shows 1 review but when you click to read review it goes to "be the first to write your review!" no reviews below default theme cache cleared different browsers not logged in all the same result Link to comment Share on other sites More sharing options...
0 vzex Posted August 10, 2017 Author Share Posted August 10, 2017 Get this error after I click "Be the first to write your review" Theme or TB? Notice: Trying to get property of non-object in /publichtml/shop/vendor/smarty/smarty/libs/sysplugins/smartyinternal_templatebase.php(157) : eval()'d code on line 59 Notice: Trying to get property of non-object in /publichtml/shop/vendor/smarty/smarty/libs/sysplugins/smartyinternal_templatebase.php(157) : eval()'d code on line 62 Shows zero reviews but they are there after you click on comments Also review box doesn't close when you click cancel have to click X to close Submit does leave a review to be approved it DOES show up but the total review count stays at 0 Link to comment Share on other sites More sharing options...
0 yaniv14 Posted August 10, 2017 Share Posted August 10, 2017 Clear your cache from BO, Advanced parameters -> Performance. For the 2nd issue check this commit: https://github.com/thirtybees/community-theme-default/commit/9be83a6be7cfd8a789c3886e89985775fe3ccdb6 Link to comment Share on other sites More sharing options...
vzex
27 answers to this question
