unica e-shop Posted December 14, 2023 Posted December 14, 2023 (edited) Hi everyone, I have some issues: 1. When i try to upload a product picture via the product page i get the following error: JSON.parse: unexpected character at line 1 column 1 of the JSON data 2. When i try to update to the newest thirthybees i get the following error: Module 'thirty bees Updater' [tbupdater] is not compatible with target version of thirty bees I hope someone can help me 🙂 Thanks Edited December 14, 2023 by unica e-shop
0 the.rampage.rado Posted December 15, 2023 Posted December 15, 2023 Regarding the second error - you can safely uninstall this module (tbupdater, NOT CORE UPDATER, they are 2 different modules) and update to 1.5.1 If doing so does not fix your first error please come back and we will try to help. Regarding the 1.5.1 update - you have to do couple more 'fixes' - you have to install the minify module that comes with this version and also choose, install and configure one of the two email transport modules that take care of email since 1.5.
0 unica e-shop Posted December 15, 2023 Author Posted December 15, 2023 12 hours ago, the.rampage.rado said: Regarding the second error - you can safely uninstall this module (tbupdater, NOT CORE UPDATER, they are 2 different modules) and update to 1.5.1 If doing so does not fix your first error please come back and we will try to help. Regarding the 1.5.1 update - you have to do couple more 'fixes' - you have to install the minify module that comes with this version and also choose, install and configure one of the two email transport modules that take care of email since 1.5. @the.rampage.rado Thank you very much that did help with the secound issue, but the issue no 1 is more serious, do you have any idea of how to fix it? 🙂
0 the.rampage.rado Posted December 15, 2023 Posted December 15, 2023 1 hour ago, unica e-shop said: @the.rampage.rado Thank you very much that did help with the secound issue, but the issue no 1 is more serious, do you have any idea of how to fix it? 🙂 This error might be caused by many factors. Did you make any changes to the core (overrides, etc.)? Is it actually uploading it under this error or not at all?
0 unica e-shop Posted December 15, 2023 Author Posted December 15, 2023 3 minutes ago, the.rampage.rado said: This error might be caused by many factors. Did you make any changes to the core (overrides, etc.)? Is it actually uploading it under this error or not at all? No, and no it doesn't upload at all, everything else is working - this error only shows when i am uploading product pictures
0 the.rampage.rado Posted December 15, 2023 Posted December 15, 2023 OK, Could you press F12 in your browser and tell what errors pop there when uploading the picture?
0 unica e-shop Posted December 16, 2023 Author Posted December 16, 2023 21 hours ago, the.rampage.rado said: OK, Could you press F12 in your browser and tell what errors pop there when uploading the picture? Here it is 🙂
0 tomi161 Posted September 26, 2024 Posted September 26, 2024 Do you have any solution? I've the same problem.
0 tomi161 Posted September 26, 2024 Posted September 26, 2024 I've deleted override/classes/image.php and it works.
unica e-shop
Hi everyone,
I have some issues:
Edited by unica e-shop9 answers to this question
