Issue with upgrading modules
TB is asking my to upgrade modules but when I try to, I get this error:
4 errors
  1. Failed to download module "coreupdater" from api server
  2. Failed to download module "mailalerts" from api server
  3. Failed to download module "statsmodule" from api server
  4. Failed to download module "tbphpmailer" from api server
4 answers to this question
That will be some 'security' measure installed on your server - firewall, antivirus, or something similar that blocks your server from downloading zip file.
Or maybe write permissions for /modules/ directory
Fixed permissions, disabled firewalld, disabled csf, still same issue.  Is there a port I should open to allow connection to the api?
Edited by movieseals
