CSV Import feature: How to CSV import update weight and dimensions of combination products without adding required fields to the CSV?
Is there a way to only update the impact on weight and impact on dimensions of combination products without adding the required fields of Attribute (Name:Type:Position)*
and Value (Value:Position)* to the CSV?
Or, as a workaround, can I export all combinations so they already have the required fields? Because adding the required fields manually is equally if not more labour intensive than adding the weight and dimensions manually.
6 answers to this question
Using Cursor, I have created a module that modifies the CSV import function to support the import of CSVs using the combination reference. It updates weight and dimensions. See attached, in case useful for someone as is or as a basis for further modifications.
comboweightupdate.zip
Try using chatgpt to build you a python script that manipulates your csv and adds the weights based on your request.
You'll have to be descriptive in your request and try couple of times until you achieve the proper result but in the end it will make you the script.
You'll have to install python and after that run single file in order to output your corrected csv that you can import in thirty bees.
But this does not address the problem of the required fields, if I understand you correctly? But I could try to make those elements not required. I would rather not mess around with the core if not necessary, though.
