Posts posted by zen
I understand, so the best is to modify this files :
\admin007\themes\default\template\controllers\themes\helpers\options\options.tpl
and also \classes\Theme.php
in order to show the button for the module..
But I really hope to have only one module at the end, so for Theme community I suggest to upgrade/modify the themeconfigurator module accordingly to the needs and for Niara starts to integrate this new module : thememaster.
The advanced settings page is again another place for theme settings, but as it is "advanced" maybe keep it like this is OK.
Can you provide the csv your are trying to import, so I can test also on the same conditions ?
- 1
I see you mention the themeconfigurator module,
yes it could be a good option to integrate new options into this module for the community theme
41 minutes ago, SLiCK_303 said:
It would be nice if this module would save different setups for different themes. At least the two community themes...
For Now I just wanted to target Niara theme, making it able to modify also the Community Theme is pssible but will be much more complicated.
When you talk about different setups, is it like demos or color/setting Pack that can be installed in a click ?
One more option added : Sticky Menu on Scroll
- 1
no problem for Module Installation and geo database download and update.
The Module seems working fine with my first tests.
Nice JOB ! 🙂
- 1
- 1
You need to setup rights for each groups on the category setting page, and setup each customer to the correct group.
1 hour ago, MichaelEZ said:
Hello,
so I´v this problem with shipping, We are using this system :WEIGHT :
0.001 - 0.1 kg = free
0.1kg - 1kg = X €
< 1kg = X €
When someone add "free shipping" item to shopping cart (it works), but when another item without free shipping ( with wegiht set to 1 for example) is added then shipping is no longer free. I woud like to change it to stay free.
So you want all orders to be with free shipping ? It's not so clear, please describe more your issue.
please have a look here to this commit :
https://github.com/thirtybees/niara/commit/bfe7676bed66bca05bccddffd28c0d0aaa5799b9
it might fix your problem.
ref here:
- 1
I tested it with few installs so far and I got to the point that is was not about version installed of TB or the module but in fact it's du to URL index not correct I guess.
Please try to click on the Back Office Module configuration the following button : "build URL index" and "build attribute index"
Clear smarty cache and try again, it should work good on your install.
- 1
1 hour ago, DKO said:
Hi,
When filtering using blocklayered, the URL changes responding to changes made in the filter, e.g. https://front.thirtybees.com/tea#/exclusive_buy-no
But when I'm trying to enter the page through this URL, the filtering is not applied.
Any clues?
Nice catch, that was not the behaviour before.. we could use link with the filters within... have to look into that
3 minutes ago, SLiCK_303 said:
when you are using the Footer settings to turn on which blocks to show, how do you change the order they are shown? Is it still with module/positions, or not?
yes it still depends on modules -> positions
and that may be a good option to add to the module.
1 hour ago, datakick said:
Awesome. Is this opensource? Is there a github we can contribute pull requests?
Here it is, and you're the welcome with your pull requests ! 😛
https://github.com/Zengraph/thememaster
maybe it's not correctly done on github.. not related to TB... give instructions if you know what I missed.
52 minutes ago, datakick said:
Notice on line 255 in file /Users/tyruk/sites/thirtybees/modules/thememaster/thememaster.php --> [8] Undefined property: thememaster::$_html
Thank you for this report: so I added
private $_html = '';
52 minutes ago, datakick said:- <div id="slogan"> is rendered inside <head>, it should be inside <body>
Right, I better use another hook like Banner
52 minutes ago, datakick said:- You should not save Show blockcategories footer block and similar to configuration table, but derive current settings based on module hook. Right now, when I click not to show it, it correctly unhook blockcategories from footer. But I can go to modules and reset blockcategories module --> it once again shows in footer block, but your module claims it does not. Just a small glitch
Yes.. That is a crucial point.. in fact I would like to have at term only one module to control all aspects of the theme.. instead of multiple modules.
For this particular module there is no SHOW button [YES / NO] in native module, only number of column to show in footer, I'll have to test it and use the same var I guess, If it is what you thought about ?
I updated the module archive in First post with the corrections (except last point).
I didn't expect to put it on github so early.. but why not 🙂
And yes it is opensource, for the community !
Hello,
here is a module under devellopment that target the Niara theme for custom settings.
Please test it, report bugs or any ideas to improve it, together we can make a great tool for everybody that can manage from BO major changes in theme settings.
For Now it does include :
4 Tabs : General - Header - Footer - Colors
General
- Home page content
- Container full width mode
- Sticky Menu on Scroll
- Google Font Selector
Header
- Header text in top of page
- Header text font weight (light, normal, bold, bolder)
- Header text alignment in top of page (left align, centered, right align)
Footer
- Show blocknewsletter footer block : Yes / No
- Show blockcategories footer block : Yes / No
- Show blockcms footer block : Yes / No
- Show myaccount footer block : Yes / No
- Copyright footer text: textarea
Colors
- Theme settings - Colors - General
- Body background color
- Theme settings - Colors - Header
- Top page Slogan text color
- Top page Slogan background color
- Header Navbar background color
- Header background color
- Theme settings - Colors - Content
- Main page content background color
- Theme settings - Colors - Footer
- Footer background color
- Footer text color
- Footer title color
- Footer links color
- Footer links hover color
Remember that is only a beta version.. it does not include sass files and rebuild function, it just add more CSS on top of the one used in theme, mostly without "!important" needed.
GitHub repo here : https://github.com/Zengraph/thememaster/
- 2
- 3
On 10/28/2019 at 1:42 AM, led24ee said:
You need to find another solution because this modification breaks Advanced Parameters -> Email section radiobutton names to letters.
I found it.. I am opening new thread right now for this module.
5 hours ago, SLiCK_303 said:
@zen, please make a new topic for your thememaster module, as you've highjacked this thread, and your module deserves it's own topic.
I'll have several questions for you about your module once you make your new topic
Yes.. you are right, I'll start a thread for this module and work on it with the help of people who like to test or have New ideas.
29 minutes ago, lovelygifts said:
Much appreciated and you've feedback so I'm happy to trust. I've certainly no idea how to do this product combination fix anyway.
This was not about combinations in fact it was the images Types/ sizes settings that needed a fix... each image sizes were assigned to all types : products, categories, etc.. I put it in order and regenerate pic for categories.
Thank you for your trust, I'll dive into that asap and come back to you.
On 10/5/2019 at 2:34 PM, Traumflug said:
It's better to change it to just "home". Then this module works for other themes as well.
That's right and the best way to fix it properly !!
16 minutes ago, musicmaster said:There is another point. It is one of the core principles of Prestashop that everything still works when you delete .htaccess. And that helps greatly when solving problems.
That principle is left here. For that reason I consider it dirty programming.
I never tried Presta without .htaccess, but if you setup "home" as a an image type (after blog module modified) it will work I guess.
7 minutes ago, Joint Systems said:
What about PHP-FPM should that be on or off?
PHP FPM is usefull to run different version of php for different websites on a server, for example one with php5.5 and another one with php7.2 with apache or nginx running.
- 1
Blog works good usually in TB ... Mark I'll be glad to help 🙂
It seems that you didn't set the proper product combination correctly maybe, and assign to it the image by default.
I can check that if you want, plz give login in private.
Theme Master Module ~¤~with a little help from my friends~¤~
in Modules
Posted · Edited by zen
Nice to hear that 🙂
==> I just added a Google font selector with the 15 more popular fonts, just a beta version but it works... just that if is gonna be used in production it is better to look into the Niara theme and remove the call to the Ralway font if not needed anymore. The google font file used is easy to upgrade, it is coming from Gfont API https://developers.google.com/fonts/docs/developer_api?apix_params={"sort"%3A"popularity"} and I just kept the first 15 listed fonts.
Next version will show visual renders of the fonts in real time, I hope 🙂
and taking care of font weights as well as italic or others variants.
