Posts posted by zen
OK, good to know.
I remember your shop now, I said it was not in production because it looks like you don't want user to really order on it, it's seems "under work", not finished yet and not polished enough to give trust in that platform.
I understand why now, it's just the back office you need 🙂
OK Mark, I see the point in the better way now.
But How could customers prefers to pay by bank transfer ? this is the less used payment method in Europe for normal users, only Pro / B2B still use it, may I ask you what do you sell online ?
16 minutes ago, Mark said:
NB: I actually do all the order processing outside thirtybees, (ie sending the stuff, making cash sales). All Im using TB for is to put the orders into a system for my own records, because its too cumbersome for customers to register and order. They tell me in one or two conversation messages on social media what they want, then the pay me, almost always outside TB. Thats all they need to do.
I wonder why you do such a thing, if customers don't buy on your eshop, you just need an accounting software isn't it ?
Using an ecommerce website to manage all this seems like it's looking for trouble and complications.. in fact you can even use excel only.
1 minute ago, dynambee said:
64x4=256 bytes. 255 bytes is the maximum, probably because the string is null terminated using up that extra byte.
yes, sorry.. and that was the answer under the one i quoted... oups
Quote63 is the max if every character uses the max encoding of 4 bytes per code point. This is the same for any of the UTF schemas (UTF-16 and UTF-32) – Rahly May 30 '16 at 19:35 -
why 63 and not 64 then ?
Well, in my experience with some shops having a lot of uploaded files it never was a problem.. 32 caracters is a lot !!
It makes (26+10+12)^32 = 6.305501e+53 different names possible.
I guess going to 64 will make it readable even more for complex filenames, but 128 is really too much, way too much, and maybe will break compatibility on some servers settings
quote : "I would like to clarify, that linux has a 255 bytes limit per filename, not 255 characters. This is a significant difference and if you use e.g. UTF-8 encoding, you may end up with filenames of 100 characters max."
SO, OK to upgrade to 64 caracters maximum... but no more is needed I think
I am maybe not answering your question for real... but I can tell you that each category can have only one parent,
products can have also only one categorie 'by default' BUT can be assigned to as much categories as you want.
The breadcrumb when viewing a product will show the default category path of this product.
Very interesting thread, let's start to upgrade Niara with better mobile experience ! I am agree to spend time for that and make a super mobile friendly theme 🙂
On 9/11/2019 at 7:38 PM, Pilou said:
Je viens de voir que sous Chrome, ça fonctionne parfaitement.
C'est juste avec Firefox que le problème apparaît.
Il n'y aurait pas un plugin sur ta version de Firefox qui empêcherait certains scripts d'être chargés ou fonctionnels ?
6 hours ago, pessoal2004 said:
I’m using TB 1.0.8 and everything is fine.
Now I installed TB 1.1.0 and in admin page I get the ThirtyBeesException:
Unable to load template 'file:/var/www/html/
in file vendor/smarty/smarty/libs/sysplugins/smarty_internal_template.php at line 185
185: throw new SmartyException("Unable to load template '{$this->source->type}:{$this->source->name}'" .
Any ideas?
Not for sure but I can have a look, please give credentials if you want
Also you can roll back your online website to TB 1.0.8 version, and try to sort it out on a dev version.
- 1
I gave you my help in PV but you canceled it.. so what to do ?
How to help somebody who knows better way..i Wonder ?.....
Lucky that that your website is not in production for real
Mark: "Ok so I need to know what the settings should be "
Zen: The settings are all yours.. it depends on the result you want in your front office.
seems like something is broken ... the url for the pic seems not correct : "/product/" should not be there or it is your root directory on the server for this website.. I doubt this.
but the images path are good : https://product.solutions.org.nz/img/p/1/7/9/179.jpg
this image on the exemple you provide does not exist : 194, so the repport you have when regenerate thumbnails is logic.
But still now, your images settings are not correct.
egos are boring.
Nice... AND usefull !
3 hours ago, Theo said:
I've created a new issue request here
https://github.com/thirtybees/thirtybees/issues/1058I suggest a solution, here is the pull request : https://github.com/thirtybees/thirtybees/pull/1060
- 1
- 1
16 hours ago, Occam said:
This already has a tiny disadvantage: the Niara theme won't find the images afterwards, because in the theme as well as in many modules the picture format names are hard coded - no matter what @zen believes.
I do believe that everything can be fix.. otherwize I don't know what you think I believe... I just want to help this user on his particular case, that should not happen, but before fixing the core, this user needs specific help in his settings, and I'll provide this care if he accepts.
I know images are harcoded, that's where the matter starts, Also there is way too much images sizes for produits... only 3 or 4 will be enough and will help to maintain an image directory light.
If you want, I can fix that for you with BO Access, as u like 🙂
Now you did this, your theme request this image :
then you need this image setting : community-theme-default_cart_default,
what size is it ? I don't know but it's should be square I guess.
Also on the same page you need also this image : https://product.solutions.org.nz/98-home/3000-lumen-headlight-with-sensor-and-red-light.jpg
and that is "home"
datakick was right : you need "home" as a default image size, but it's not available on your settings, so it's not created, therefore you can't show them in front office.
You need to edit the images config, and delete all images sizes wich are not used and estup one for "home" and others missing.. then regenerate thumbnails !
Wich theme are u using right now on front office ?
you can give the shop URL please ? In private if you prefer.
Just now, Occam said:
Smarty cache isn't the problem in this case, activate once the option recompile.
it's not the problem if your setup is correct.. there is also the first selection for "never recompile TPL files"
2 hours ago, danae5d said:
Hi, I put the api Key but I have an error in the frontpage "This page has not loaded Google Maps correctly. Discover the technical details of the problem in the JavaScript console."
that's right, you have to check on the console the error log and post it here.. if you want us to be able to help you.
Admin Creating Orders and Customers
in Technical help
to "polish" it you'll need to dive into webdesign and UX, make a nice logo, take care of small details.. it takes a huge amount of time and dedication , endless job in fact !
Don't you use bank transfer in your website too as a first choice for your customers ?
Also, to speed all the process of registering, you can add a social media plugin for login, it will fill all the infos like mailing adress in one click for your customers.
One page checkout process is also a good option in your case to simplify ordering process.
Customers need to trust your shop, all theses details increase it or make them run... having a direct contact with the seller is a good way to bypass the website trustable quality, but it increase a lot your job as much as if it works good in a close future, you won't be able to take care of all these orders yourself.. then having a proper website is helping a LOT, and from there you can force almost everybody to order online only.
Best regards and good luck 🙂
