Posts posted by zen
How to auto apply all thoses fixes when migrating from a presta 1.5 for example...
If I try to click to fix each line.. it will takes ages ^^ would be nice to apply all fixes in only one click 🙂
If all the setup is OK, and customer group permission as well, then you might think about deleting carriers and re-create them.
Quote
What does it mean? It means that core updater will now look into php codebase and extract metadata from object model classes (like Product, Customer, or Order). These metadata describes exactly how database should look like -- what database tables should exists, what columns should they contain. It describes primary or foreign keys, column type, default values, collations, etc..
does it also look into overrides php code to extract added fields needed by modules or personnal modifications ?
GetDatackick solved it :
QuotedisplayPrice: always replace USD symbol
When Auto format is turned on for some currency, displayPrice javascript method will use browser built-in support for currency formatting to format currency in specific locale. It does so by evaluating this expression: return price .toLocaleString(locale, { style: 'currency', currency: 'USD', currencyDisplay: 'code' }) This code ensures that the number is formatted using 'USD' string in place of currency symbol. This 'USD' string is then replaced with actual currency symbol. However, there was a bug - this string replacement wasn't performed when no currencySign was passed to the function. In such case, the string with 'USD' symbol was returned. This commit ensures that this USD symbol is always replaced, even with the empty string. Related to issue #865
1
It comes from the function displayPrice that needs some correction in the file : js/tools.js
line 117
if (currencySign && currencySign!== 'undefined') { formattedCurrency = formattedCurrency.replace('USD', currencySign); }
And I am not sure it really needs to be there.. why replacing to USD, in others files it setup by default to euro € symbol... strange, maybe somebody can explain where does it comes from.
57 minutes ago, musicmaster said:
Yes, I didn't noticed it before... but this USD has nothing to do it here and was not there in 1.0.8 version.
thank you for this report.... let's dig it more and correct it, i'll keep you updated here.
It is complicated 🙂 I hope to have time enough to fix it correctly and not in a hurry.
I propose this solution... but Maybe there will be some side effects, here is the product.js files to put into the /js folder of the Niara theme.
It works for discounts based on amount of products bought, please test it and repport it here before I post on github the modifications.
1 hour ago, Enev said:
However, when I select 7 products the price changes but not the discount percentage, it still shows 10%, although it's already 15%:
I found this somehow misleading for the customer, as I expect this value to change dynamically just as the price changes.
However, I'm not sure if it's intended to be that way by design or is it a bug because for other "non-promotional" products you don't see the price reduction percentage at all. For example I've set this product up to have discount only for 3+ pcs.:
Great catch, I'll try to investigate this JS problem asap.
thank you for fixing the calculation price in the previous post.
1
quelle version de TB stp tu utilises ?
" Je suis en TB V1.1.X. Est ce qu'il s'agit bien d'un bug d'interface? si oui je ferai un bug report! "
j'ai demandé trop vite.. l'info était déjà là
sinon je suis dispo sur Skype si tu veux, ça sera plus simple je pense.
Je viens de tester sous ubuntu 18.04 avec TB 1.1.0 et j'ai pas le bug que tu rencontres.. meme en multiboutique !
1
OK, afin de reproduire le bug.. tu peux me dire quelle version tu utilises et sous quelle version PHP, c'est wamp en local que tu utilises.. merci de filer le max d'info sur la config pour pouvoir reproduire la même chose chez moi et chercher comment le résoudre 🙂
donc si je comprend bien :
- je peux trés bien creer un nouvelle catégorie dans accueil
- mais pas modifier une catégorie déjà crée et lui coller comme cat mère : accueil
c'est ça ?
Quote
I'm not talking about Skype but I am talking about screen sharing using team viewer where zen and his infinite wisdom can show me the button I am yet to press.
"You may say that I'm a dreamer
But I'm not the only one
I hope someday you'll join us
And the world will be as one "Mark, Nov 2019
what a beautifull vision.. I understand I messed with your visions, meditations, preparations and alll that things, so sorry I tried by force to bring you IRL , I won't do that again !
1
Salut Pierrox15,
tu ne peux pas sélectionner accueil pour une "rubrique courante", j'avoue ne pas être certain de bien piger.. si tu veux je peux jeter un oeil sur ta config, voir ce qui cloche, car normalement tu peux bien sur sélectionner accueil comme catégorie mère... ton site est en production déjà ?
1 minute ago, Theo said:
Oww.. that doesn't sound good. So it may have to be the TB Blog module then... which isn't all that bad mind you (imo).
Just Panda is something else in general (in terms of being wow) + the Panda Blog and Blog functionality is pretty cool.
Still waiting for feedback from @Jonny and I guess we'll take it from there...What is missing from the TB blog module (not in terms of being wow 😉 ) ? I never used the panda blog.
3 minutes ago, Theo said:
Agreed and Lol - another thing to add to the "let's not discuss list" at parties, next to "religion, politics, etc."
And woahah! - the price and time to do this just seems insane. Thanks for checking that module...
ST Themes recommended maybe this module - mind having a quick squiz at the features pls?
https://www.sunnytoo.com/product/prestashop-removing-ids-urls-module-seo-friendlyafter reading the specs.. It should do the trick for you for 29 $, if not you still maybe can ask for refound.
11 hours ago, Mark said:
The story @datakick is that at this stage no access to the backend is required. Given that I've done nothing to the codebase I'm presuming there's nothing wrong with the code and it's just something I haven't spotted yet.
I don't give strangers access to any data for no reason and that's a key principle I would suggest others follow.
If there's a problem with the code then it becomes a different story.I'm not talking about Skype but I am talking about screen sharing using team viewer where zen and his infinite wisdom can show me the button I am yet to press.
Don't try to nail me for having expectations around what I will permit others to be able to do on the site, everyone has that total right.
I don't even know who zen is, never spoke with him in a conversation as if I'll let anyone into any system like that. He offered to help then never replied when I sent a pm.
That's fine, just say so man, it's not hard to say sorry I changed my mind, much better manners than ignoring.
Mark please do not insist about this, do you remember the time when you gave me an access and canceled it just before I can try to help you ? About Images to fix. You did not say sorry at all.. you were allways right and I loose so much time with this story.
I gave you my help like I always do, others accepted without conditions for free and where really happy about that, but you are too boring by giving conditions and making it difficult and frustrating to help you like this.
Usually for payed service I NEED credentials otherwise there is no way I am gonna work for any customers... even if they want to spend 5 hours on skype or screen sharing and pay for that, it will not happen, it's not efficient!
Now, I wish you good luck for your bugs to fix, sincerely, and I hope you'll understand my point.. maybe it will help you not to have the same encounter with others dev willing to help in a normal way, remember that without trust you'll not go very far and surely alone !
2
21 minutes ago, Theo said:
Look, maybe from a technical point of view and from a developer's point, maybe it's not a problem.
However aesthetics do matter and from an SEO / Marketing expert's point of view, it's a big deal.It's not a big deal.. it's just an estetic choice, don't fall into SEO marketing spider net that will suck all your money 🙂
https://stackoverflow.com/questions/820493/can-an-seo-friendly-url-contain-a-unique-id
I can confirm that ids in URL is not a problem, just an aestetic plus, you should contact support for Panda theme to fix it for you, as it is a purchased licensed product.
In fact ids in URL can be a real plus when you'll change your blog system, redirections will be easier !
2 hours ago, Pierrox15 said:
Hello,
Is it possible to move a non-root category to a root category?
I would like preserve the primary key "id_category" and its branch of sub-categories.
Actually in the BO Interface for category edition I've got radio button form and I can't select root. I hope it's just an UI bug 🙂
Thanks for your help
I don't really understand what you want to do.. BUT you can't change a non root category into a ROOT category as you already have root category i believe.
If you activated the multishop, then it coming more complicated to explain, hope you are in a sigle shop 🙂
I actually use this : Advanced Search 4 v4.10.16 - by Presta-Module
on a TB 1.0.8 since few month already and having no issue regarding that.
I do have one client with Panda theme installed... I just upgraded it from PS 1.6 to TB 1.1
For the blog side, they now use TB blog and have no problem for URLs without IDs in it.
3 hours ago, Mark said:
No worries, you'll not be logging in, there's no need to. I don't give randoms any unnecessary access when not required.
I don't often get the time to work on this site.It's the blog that's that not functioning, that's all
Probably just a button somewhere that's escaped my attention.
like I said, I lost my crystal ball otherwise I would have helping you with my tremendous powers !
core updater database schema
in Other native modules
Posted · Edited by zen
Ok..i unserstand that but i'd like to make it possible for those who'd like to, even with danger !
Because now ..it will take me maybe around 2 days clicking all the Time to fix it all..please tell me where to engage all recommandations even it breaks the dB afterwards..i'd like to test it.
