zen
Posts posted by zen
  1. Yes, the best option for you is to scan files with some tools, and inspect all directories that seems suspect.
    Otherwise you can just use you database (cleaned from any new admins or employees created) and install a brand new instance of TB.
    It will take time anyway to be confident again on your system, but there might be a module that was the Hole for this to happen or your provider is just not secure at all.. change it fast !
    Best regards 🙂 and Good Luck !
  2. 8 minutes ago, LCortes said:
    I think that it will be good if we can change all colours: NAVBAR - background, text and hyperlinks, MENU - background, text, hangover... Maybe button colours and button hangover
    OK..I'll do that Asap and post the archive here.. and update on github 🙂
    for the changes to show faster on you browser, you can try to empy cache in the back office.
  3. Hello everybody,
    - when apply changes to theme, it take so long to take effect on website. I refresh page page with F5, but take long time... is that normal, or is my ISP?
    => it's not normal nexty time try to refresh with CTRL+F5
    - in "theme settings - colors - header" is that possible to add more fields? the "Header Navbar background color" works fine, but is not possible to change the text color of Navbar.
    => ok you need more fields.. tell me what and I'll add it too.
  4. Hello Peter..
     I'll try to give you help so let be clear that  if you have ONE server and you host one website on it (I am not talking about domains) you can activate the multishop feature and then share the stock or not between instances.
    If you have 2 serveurs with 2 different websites.. you'll need to update DATABASE directly with a cron task from one DB to another one or use other techniques like Web API request for stocks update.. or jsut for confirmation before validating the cart.. anyway it is not a native function at all .. when you hjave 2 DBs.. you need a bridge between them if you wan to connect datas.
    On a more serious way you may have already en ERP that manage your stock and customers, or maybe some sort of P.I.M  (Google it if you don't know), if it's the case then you'll have to synch the stock on each TB instance with a script that can connect to your software where the REAL stock is.. some uses CSV or Excel files for that purpose.. many ways are possible.
    • Thanks 1
  5. Hello,
    I recently didn't have much Time to polish this module...but yes it should work on niara theme, just download it and install by FTP or with the proper zip archive, if downloaded from github you'll have to extract files and make the zip again of the archive directory.
    I wish to finish this module if people like it..but for now there was not much return, maybe it will change soon, let's hope it.
  6. 5 minutes ago, AnnaLisik said:
    All I want to establish is that if people ( = potential devs) would come to the repo, they will see known (and well-established) nicknames so they will instantly catch.
    That is true.. who are you thinking about for taking the ownership of the repo ?
  7. 2 minutes ago, AnnaLisik said:
    Im affraid Im not following what you were trying to communicate here?
    he's talking about the money income for TB enterprise that will need to be redone again.. that will take time too.
  8. Bonjour tout le monde,
    si vous êtes francophone, merci de répondre sur ce thread ça permettra de faire un peu de stat et de connaître le nombre de personnes actives (où seulement ceux qui lisent les posts en anglais) sur ce forum. SI on est assez nombreux y'a moyen de faire vivre la partie FR du forum encore plus, c'est vraiment dommage que TB ne soit pas plus utilisé en France, lieu d'origine du code source du projet forké.
    Si vous avez des questions sur TB et vos futurs ou présents projets web, n'hésitez pas !! je vais faire de mon mieux pour vous répondre selon mes capacités.
  9. 4 minutes ago, AnnaLisik said:
    Why do you think that forking is not ideal solution here?
    it's still possible to not break TB reputation (even if it's small) if it's not forked, and keep on increasing it while keeping brand, logo, forum, community etc..
    • Like 2
  10. I recommand not to rush to choose the best thing to do, to be prepared and think twice before rushing into any plan otherwise it might and up like this :
    Hey... Anyway we had some fun !!
    • Haha 1
  11. 1 minute ago, Theo said:
    Nice to know 😀
    Very Nice Site & Compliments, well done! 😃
    thank you 🙂
    I just lost all my comment .. that was really well written and everything well balanced, such an intelligent post.. ha ha ha
    and it's all gone after a refresh with a bad click on the "prev" button mouse... 😞
    Anyway I just wanted to say : I'd like TB to remain Open Source for sure and free for all also.... But I'd love to see a CE / Pro version of TB that comes with entreprise support and personnalized quality hosting, people will surely pay for that.. all bugs will be fixed, all basics needs for entreprises connections to ERP, ERM, CRM, PIM, and all others 3 letters tools that you imagine.
    Most of the entrprise needs are similiar and if we have an expert team, it will rock for sure.. imagine an entrprises that can deal directly with the software programmers.. that actually never happen, most of the time this company works through agencies with licenses.. and the result is often mediocre.
    I can help for servers and hosting for TB in Entrprise version.. and I spend a lot of time with scripts for products / customers/ orders Sync, that means, like many of you I already have a lot of already make code that can help others entreprises in their goal.
    Note : I never talked about a clouded TB version for public.. that is not a good idea.
    Copied from Magento website , about the entreprise version :
    Quote
    About the Feature List
    Enterprise Edition erases the boundaries of what is possible, giving you the power to create bold and unique shopping experiences that will transform your business.
    Built for rapid and cost-effective innovation, the platform combines rich, out-of-the-box functionality, enterprise performance and scale, and powerful business tools to keep you ahead of increasingly complex commerce operations and growing customer demands.
    I think it's one of the best way to make TB alive and growing in the future, I used it a lot for entreprises websites and it works really GREAT !
    • Like 2
  12. Well Well  Well.. I find it encouraging to see so many people trying to find a way into this mess !!
    I will tell you that I am still deeply involved in TB and will keep on doing my best to improve it like fixing bugs founded in core, I want to keep on doing it for free.
    Working for free for TB is good, I like it and it's not for free at all in fact, as I use it on many projects for my customers and this is not for free.
    Using TB instead of Presta 1.7 or OpenCart or WooCommerce or Magento is just the best option available for me specially for one point : All of the modifications I needed to do in CORE will be included in next version after adding a new pull request, but we need people taking car of that like trumbflug use to do and Datakick is still doing now.
    Just to resume : I'll be on the boat when TB sinks or not, hoping to keep it moving into the ocean of ecommerce CMS.
    • Like 10
  13. 1 minute ago, datakick said:
    To make things clear - by "not being interested" @lesley means I turned down his offered to sell me the tb company. The asking price was 30x more than I could (or would) ever pay for it. And frankly, even if the offer was 30x lower, I'd still have to thing very very hard about it.
    to Sell it ? ok.. now I also join @toplakd on the soap opera thing ! it's mind bogus^^
  14. 5 minutes ago, toplakd said:
    As its open source, one can start its own fork, but for that one needs nerves, because negativity is mostly higher than positivity, especially on free stuff.
    As @Traumflug said, you can not see that much negativity on prestashop forums like we are able to see here 😢
    I think you are exagerating, Presta had and still have a lot of negativity on the forum but they also have a Community manager and moderators that delete a lot of unwanted messages, that sucks !
  15. 2 minutes ago, lesley said:
    I know everyone here is waiting for me to come and comment, to say that everything is under control, but if I said that we all know that would be a lie. The fact is I am getting better a lot slower than I anticipated and I am unsure what the future holds. But I am open to what it does hold. I am also open to answering any questions you all might have.
    Good to know that you start getting better 🙂
    • Like 2
  16. 3 minutes ago, toplakd said:
    I do think all should stop with this mass hysteria.
    It all started with corona,
    little later @datakick saying goodbye
    3 days later ownership over @thirty bees was taken together Patreon revenues
    and on April 20. the sun went dark.
    Cool down, drink some 0% beer and enjoy the sun for next 5 days
    OK, but this is not new... Datakick is leaving because of this unclear situation, why not take the opportunity to move forward instead of let it become rotten.
