Posts posted by zen
For this module to work you have to rename his directory to :
prestashoptodolibarrpro
and it will work.. you can do it before you repack it on zip.. or by ftp when uploading files.
- 1
5 minutes ago, Beeta said:
that menu is very useful for the customers. the majority of customer don't know what the burger menu is and how to open it. 😞
another thing, is it possibile to choose to have a vertical menu?
OK.. can you provide me a demo for the menu you'd like to see ?
Best Regards
can you provide a link to have a look ?
8 hours ago, Mark said:
In setting up 3rd party access to my site's data, I supply a url to the image on the website, which I want them to download and sync to their server.
However, to prevent "the internet" from downloading images, TB seems to prevent this... which is good.
Is there an easy (no coding adjustments, just UI ) way by which we can permit some IP's to access and download the images?
If you have the image URL nothing is holding you to download it from an external server, except if you install yourself antileech system.
But you need the real url not the rewritten one, that can be done from a php script, I can help you as I already export images link for websites synchs.
12 minutes ago, datakick said:
It works quite like build-in Accessories feature. Accessories are just rendered in their own tab, and as a product miniature. With a little bit of theme modification you could actually use the Accessories feature to accomplish this module's functionality.
I got it, and Datakick just gave a simple solution to do it, it so much like the accessories feature, 100% agree !
1 hour ago, Bull said:
Is anyone aware of a module similiar to this, that works with PS 1.6 / TB?
I read the description but I was not able to understand what this module does for Real, can you try to explain it more clearly than the addons description ?
but without any DB configured you won't be able to start TB in front or back office, no user login, nothing can work !
so it's strange, very unusal.
Just now, Kenneth Nielsen said:
I think I located the issue, it dosn't connect to the database. But during installation, no errors came up 😕
How do I change database setup in TB installation?
you can edit this file : config/settings.inc.php
And modifiy theses lines for DB access:
Quotedefine('_DB_SERVER_', 'localhost');
define('_DB_NAME_', 'DATABASEName');
define('_DB_USER_', 'DATABASEUser');
define('_DB_PASSWD_', 'DATABASEPassword');
define('_DB_PREFIX_', 'tb_'); -
10 hours ago, Kenneth Nielsen said:
Hi there,
I have just installed Thirty Bees for the first time, everything went smooth and page is online.
However, when I go go my backoffice and click on products, I can see "Products 10" but no products is listed. Like they are filtered out, but nomatter what I do, I just cant get any listings.
The same problem occours in Category (Caregory: 3).
I can create new product and category, but when I press save, it just pops out int he list view and no listed procucts or catagories.
Anyone have any idea what this could be caused by? Its driving me nuts, been messing around with it all day. Only thing I can think of is a faulty template...
All the best
Kenneth
What is your hosting provider ?
also, I can have a look if you send me access in private.
Best regards.
I activated smarty cache on Performance setup page and all the options for CCC (Combine, Compress and Cache) are turned ON, I had small problems with minified css and js, that now is fixed 🙂
- 2
2 hours ago, Wartin said:
I was just seeing the new menu, very good!
This is a topic very discussed, but I'm not sure if it should be managed by the theme or not. I had deleted the options I didn't want to appear in my Niara. I'm talking about "Mr. Mrs." or Birthday date. I didn't need those, and had to change the tpl.
Maybe this could be a theme option?
That means you want to get rid of Social Titles and Birthday on the user infos..
=> Mission Done, you can select to ask gender title and birthday or not in the theme master Module.
- 1
1 hour ago, cienislaw said:
Disconnect? is this Matrix?;-)
Wat do you want as a default field : "Disconnection" instead ?
Updated, I modify this account Hover menu to add direct links to account details :
Just added a dropdown userlink on nav top header :
Hope that it will be usefull for you !! 🙂
- 3
20 hours ago, Wartin said:
The overlay works as expected in desktop. On mobile product's images are pretty big, so you have to vertical scroll to see the whole thing. Maybe two rows, the first one for the image and the second with product's name, quantity and total.
Other thing I was thinking about. What if you just delete the title 'Addresses' here:
It takes a lot of space and it's not that important.
You now, have a new custom variable added to the module thememaster that
"Hide step titles on order for mobile "
tell me if it fits your needs 🙂
- 1
it says that the theme is already installed.. so is it working already or what is blocking you now to use TB on this install ?
- 1
On 11/10/2021 at 10:10 PM, vincentdenkspel said:
When i select a category and form within the category list click on 'add to cart' the product is added to the cart.
It would be nice the the popup is show in which is confirmed that the product is added to the cart.
You now have to scroll to the top in order to make sure it is addes.
This is fixed, as I put back the popup overlay message when adding a product in the cart, please confirm that it's working as well for you.
Quote
2. Last item in product view is half width compared with all others. Also I see there is a dynamic number of items per row (desktop) - I have mixed feelings about it.
this is fixed and the listing grid will be something that I want to make it customisable from backoffice from dynamic to fixed numbers, for now it is dynamic with flexbox system and justify alignment
Quote3. Text size for mobile looks like the same as for desktop making it quite big and page very long (Samsung S8).
Which text would you like to see decreasing in size for mobile ?
3 minutes ago, cienislaw said:
from what I see here current demand from community focuses on checkout experience, which of course is important, but what about all other parts of the shop? I don't want to force direction of development, but theme should be 'complete' first, before digging into details, especially those which are important for individual merchant and feet nicely into service mode you mentioned above.
The the purpose of this thread is to complete the theme for the basic needs, adding more function is for the next step but if it's easy why not doing it on the way.
Waiting for your bug report in order to fix them. 🙂
10 hours ago, Wartin said:
It's awesome already. I liked the 'add a new address' that appears when you unclick same address checkbox (maybe the other 'add a new address' could disappear in order to not have the same button again.
I was trying mobile and noticed this:
It's a little detail, but maybe you can make that modal bigger without horizontal scroll.
"the button could disappear in order to not have the same button again." => yes.. but it will make some moving effect into the page that i don't really want to happen.
"It's a little detail, but maybe you can make that modal bigger without horizontal scroll."=>That is fixed 🙂
13 hours ago, vincentdenkspel said:
Hi,
The theme looks nice.
Hope you can add this.Will there be a free version and a paid version of the theme ? If so what will be the difference ?
Thank you for this report, I gonna fix it soon.
For now I still don't know If there will be a paid version one day, I have to finish this one first.
I might also provide later some services to integrate custom theme design/mockup for merchants.
1 hour ago, zen said:
OK, I might add this as well and connect it to the module so user can decide to show it or not on the shopping cart summary, please wait before I can add this feature 🙂
Job done, I added the quantity on the shopping cart prod line with and the option to show it or not on the theme Master module.
QuoteShow stock quantity in cart: YES - NO
- 2
1 hour ago, Wartin said:
OK, I did changed the colors.. the active step is dark now and to complete is light grey and completed is dark grey
- 1
- 2
Default language
in English
Hello vincentdenkspel,
When I try to visit your website i do have the dutch language choosen by default.
So it seems to work good 🙂
