Posts posted by zen
5 hours ago, wakabayashi said:
Is there any guy with experience in server administration? All my sites are down, due to a MariaDB issue. I don't know, how to fix it myself and need (paid) help from an experienced server admin.
Edit: ok I probably found a guy, that can fix it 🤞
Hope you can fix it fast, good luck !
14 hours ago, António Moreira said:
How to find a template designer for thirtybees?
Thank you.
I actually can help you for that, what are your needs ?
6 hours ago, Euria said:
Warehouse, Panda, Transformer, all these themes are running on TB to a large extend. There are some glitches and these themes need maintenance (over time). However, all those themes are a bit boring and around for years now. I would like to see features as in Visual Composer to be able to pimp the themes and to show some cool features.
Well, I believe this will not happen soon, Visual composer is a huge piece to implement into a new theme.
Are you guys willing to pay for a theme like that (without visual composer or elementor in first version)?
The most common system now is to subscribe for a payment each year like WP and WOO do for all their themes, or one time fee only but have to pay for next updates after purchase ?
How many people interessted in a new modern theme for TB, what are features do you need ? I hope elementor or visual composer is not one of theme as I am not fan of this tools as it build messy html code. I already started a Boostrap 5 theme.. wich seems not being used by community, so I stopped publishing work.
Al sunny themes where good in the begining but now support is dropped and it looks too aged, as it still use Boostrap 3 only, all the work is now done for 1.7 version only in sunny team.
- 2
On 3/25/2022 at 6:31 PM, bhtoys said:
Sorry to bring up an old post. But this has happened again.
I can't access the Duplicate URLS link in the backend.
500 error.
When I try to repeat these steps from before, I get an error message saying " please update core updater module "
This, combined with me being unable to use Freindly URLs is making using ThirtyBees frustratingly impossible.there should be some reason for that, your hosting cie changed parameters or you are running out of space, or memory while trying to use TB now... you need to debug it first and optimize your hosting config : php.ini mostly.
What kind of hosting company and service do you rent actually in order to make TB run ?
For bulk actions there is no officialy supported software for TB , even store manager try with very first versions of TB.. not enough customers to maintain this need, but it still should work fine, as well as merlin back office and store commander that works for presta 1.6 but the support is no more available for this version.
Otherwise welcome on board vallka .. I can recommand you to try my new theme based on boostrap 5 available here for your tests : forum thread
maybe a good opportunity to make something better !
12 hours ago, Theo said:
I am also wondering ^^
Here is the Slack channel : https://join.slack.com/t/thirtybeesgroupe/shared_invite/zt-112btgw5f-1LyegnmiMfBOH~HvC6cA5w
17 hours ago, cienislaw said:
yes, as in TB repo - all parts are separate. and versioning will for sure help;-)
that is why it's on MY repo.. and for me this is the first version available that is posted : SO versioning start here.
If you want to split all.. then integrate it correctly on TB repo 🙂
Best regards 🙂
6 hours ago, led24ee said:
I don't get it. For example thememaster module. I have found many of them, some are many years ago, size is different, but they are all v1.0.0. How the hell someone supposed to know which one is working ? Now there is thememaster-master.zip and TB1.3 shows me that this module install is done. And yes ... there is again Thememaster v1.0.0. not thememaster-master. Or I understand something wrong ?
the ZIP of the THEME contains the theme installation package, including the modules wich is also the sames pack I post on the Git repo.
Here it seems that you talk about the module theme-master which comes included in the package, but has is own repo as well. And the thememaster-master.zip is the zip build on github when you want to download files, don't install it if you theme package, of course.
But the theme master Versionning might need an update 😅 that's right !
Here is the GIT depot :
https://github.com/Zengraph/cisero
it includes themes and modules, maybe it's not the best way, should they be separate ?
1 minute ago, Mark said:
I'm looking for something that will process by the same rules as the website but go past admin first for approval before being actually processed.
What do you mean by that ? you want to start import from BO only ? After being logged in, is that it ?
QuoteThere's probably a module somewhere that I could use, but external to the site is what I'm after.
I am lost.. what do you want to do then ?
I do have personnal scripts that use CSV files to synchronise / import images, customers and products, it's external of TB website but use same config and settings files.... what do you need to know about such a system ? I use no module as it is a full different system with many other scripts for stats, etc... all are triggered by cron task regulary.
3 hours ago, cienislaw said:
thanx for the explanation, I will try to look into this. one codebase with extra smarty templates will be easier to maintain.
Yes, that is the good thing to do, keep us updated for that plz 🙂
9 hours ago, cienislaw said:
I have one question about zen modules - are those forks really necessary? from quick code comparison I don't see any revolution in there which override in theme won't handle. as long module logic is the same IMO forks will only confuse ppl. now we have only 4, but what if there will be more?
Yes, it is necessary as theses modules delivers html code from php, and there will be more forked modules for this theme if needed..
otherwise you can also refactor the default modules in a better way, so all the html code is generated really from smarty files, it's a good thing to do.. Ithen we can drop forked/modified modules and only use tpl themes files for overriding style.
Have a nice day 🙂
22 minutes ago, Briljander said:
Sorry, didn't mean to take focus from your thread.
no problem 🙂
Does anyone has any idea to improve the Theme ?
17 hours ago, Briljander said:
I have read the changelog earlier but is it faster, more secure or is only the codings standard that differs?
For technical discussions or issues with bootstrap 5, I recommand to open a new thread.
You can also check all point in details here : https://superdevresources.com/bootstrap5-vs-bootstrap4-whats-new/
On 12/11/2021 at 8:30 PM, nickz said:
Yeah and some people do like a surprise, repetition bores so lets encourage the curiosity of people rather than making them dumber. Just my 2 cents 🙂
I am thinking the same, but I'll add an option to hook it currencies and language selector in top/header position, so that everyone can choose where to see it.. but in small screens it will be hidden, that is why i need to make the bottom action bar for mobile asap.
Edit: I finished this task of adding theses blocks on TOP of website, and also updated the archive in the first post.
=> It needs to be activated on the Thememaster module config, under Header section, also you need to have different currencies and languages activated in your shop to be able to see theses blocks in action.
28 minutes ago, cienislaw said:
maybe its time to put it in repo?;-)
I'll do that when people will have test it more so i can fix most of all bugs before putting it on Github.
Also .. you won't get an archive like that on git, it will be missing things inside 😞
16 hours ago, Pietroalberto said:
How do I try it out? I downloaded and loaded it from "add new module" but I don't see anything (it also happens to me with other modules that I would like to try, where is that I'm wrong) CIAO
Hello @Pietroalberto
in order to install this theme, with the modules bundled in the archive, you need to go in the back office
Preferences > Themes > "+ Add new theme" (first upper right button)
from there you can upload the zip, after that you might need to recreate proper images resized.
8 hours ago, Wartin said:
I was trying the last version in the demo site. I have a couple of suggestions. Is it posible to hide the slogan bar? In mobile 'test slogan' text takes some precious space.
It is already available in thememaster config :
Theme settings - Header => Header text in top of page ( text to be displayed in the top of pages as a slogan. Leave empty to not display the block. )
8 hours ago, Wartin said:I was thinking how to make it fit in one horizontal bar. Maybe use just 1, 2 and 3 without the zero? Or maybe Summary/Address/Payment?
=> I tested it on the smallest mobile resolution available today : 360px width, and it stays on one line only.. what device are you using to test the mobile version ? I gonna add some code according to this min res.
8 hours ago, Wartin said:I fixed it, a <span> where missing on the TPL file
9 hours ago, Wartin said:Search bar seams pretty big and heavy for mobile. Maybe something like:
I did modify the search for mobile versions, but maybe it should be included in the bottom tool bar that needs to be written, soon I hope.
9 hours ago, Wartin said:And maybe these centered?
It is centered now on mobile screen sizes..
I updated the archive in first post to download.
- 1
I just released the Archive on a Zip, that can be installed.. enjoy and please report bugs and improvement, you'll find the ZIP file in the very first post of this thread.
- 2
- 1
On 12/4/2021 at 11:27 PM, Beeta said:
you can see in big websites like prozis.com for example
https://www.smashingmagazine.com/2019/08/bottom-navigation-pattern-mobile-web-pages/
OK, I got your point, I am going to implement this later, that is good for mobile actions !
thanks for your contribution
- 1
I just modified the slider, so there will be different options for homepage, this one is based on boostrap 5 and can handle title, sub-title, description and url link, it is responsive too !
I also rearanged the header for mobile version, it more narrow and fits better.. I got to find a better way for search bar, hidding it on small screens.
I added also an opacity field on thememaster / Header color panel, so the submenu text scrooler can be transparent and let see the slider on desktop.
Waiting for your feed back now 🙂
- 1
in Theme help
You can simply use My ThemeMaster Module for that task, here is the Zip attached on the first post of the thread :
